Does the fusion process cause a chain reaction?
In summary: Vol. 83, Iss. 9, Sept. 2009, p. 095005 In summary, a fusion chain reaction is not the same as a fission chain reaction. The products of fusion reaction would primarily distribute their energy into the plasma to keep the plasma sufficiently hot to continue the fusion reaction. Otherwise the energy would be extracted for generation of electricity (or heat).
waldo72
does the fusion process cause a chain reaction? or in a fusion reactor are lots of hydrogen atoms released to produce energy. does a fusion reactor heat water and produce steam to generate electricity? if you know anything then please let me know. thanks
A chain reaction in a fusion reactor is not the same as in a fission reactor. The products of fusion reaction would primarily distribute their energy into the plasma to keep the plasma sufficiently hot to continue the fusion reaction. Otherwise the energy would be extracted for generation of electricity (or heat).
The D+T reaction produces He4 + n (fast). The n leaves the plasma, but the He4 interacts with other ions and electrons to heat them as it slows down. Somehow, it must be collected and removed from the plasma once it slows down to plasma speeds (energies). He4 does not fuse under the plasma conditions that D or T do.
Now some fusion reaction like D+D do produce products like T or He3 which can then fuse with the D in the plasma. And the T and He3 produced by the D+D fusion have high energies with respect to the plasma, so they are more likely to occur than if they were introduced at colder temperatures.
No fusion power plant, which produces net energy (i.e. more energy out than put in), has been built. The ITER experiment is currently being built in order to get closer to that goal.
If the kinetic energy of the ions and electrons cannot be extracted by direct energy conversion, then the heat of the plasma will have to be collected somehow and used to heat a working fluid (e.g. steam) which would be passed through a turbine to generate electricity (via Rankine cycle).
A chain reaction in a fusion reactor is not the same as. ...
So here you are referring to the energy produced by one fusion being part of the chain that contributes to or assists in another future event? Hmm, would a physicist describe chemical flammable combustion a 'chain reaction' in that sense? In fission each of the two neutrons is completely sufficient to initiate another fission event, not just a statistical piece of the pie. Also this ignition concept would apply only in the case of a magnetic confinement system (ITER), I believe, and not apply to an accelerator type of reactor (IEC) or even an implosion (laser) system?
In any case I don't think you can say there's a chain reaction in fusion. I'm being a bit pedantic, I know, in order to disassociate any of the popular fission bad connotations from fusion.
Yeah - I should have limited that to magnetically confined systems, as opposed to the inertial confinement systems (IC) or inertial electrostatic confinements systems (IEC), which are pulsed systems. In the latter, the thermal energy is about the only way to get the energy out. I was going for a quick answer, since I am working today and tonight.
No but apparently chemists, and perhaps chemical physicists would - http://nobelprize.org/nobel_prizes/chemistry/laureates/1956/press.html
In 1913 the German chemist Max Bodenstein put forth an idea which proved to be extremely fertile, the idea of chain reactions. This means, that if two molecules react, not only molecules of the final reaction products are formed, . . . .
Another technically important chain reaction is the combustion of carbon monoxide, not to mention the combustion of hydrocarbons.
A sustained magnetically confined systems could be construed as a 'chain reaction' in the sense that the products, particular product ions, impart their energy to heat the plasma. If one can collect more energy from fusion, than is added from various heat sources, e.g. ohmic, microwave, or neutral beam injection, or lost due to recombination, cyclotron or brehmsstrahlung radiation, or diffusion of neutral atoms, then that's not too different from a chain reaction in which at least one neutron must be survive to cause another fission from those born and not parasitically captured or leaked out of the system.
Interestingly - chain reaction has been used in conjunction with fusion, but one must remember it is not the same as the fission/neutron chain reaction.
Fusion Chain Reaction—Chain Reaction with Charged Particles
Michal Gryziński
Institute of Experimental Physics, Warsaw University, Warsaw, Poland, and Institute of Nuclear Research, Warsaw, Poland
Phys. Rev. 111, 900 - 905 (1958)
Kinetics of compression-induced fusion chain reaction
Gac, K.; Gacek, A.; Kaliski, S.; Sarzynski, A.
Journal of Technical Physics, vol. 18, no. 3, 1977, p. 311-324.
The p—p Chain Reaction
http://nobelprize.org/nobel_prizes/physics/articles/fusion/sun_pp-chain.html
Ok, fair enough, a fusion chain reaction it is!
From the Depths of Nirvana...
17th July 2007
RE: Cold Fusion...
Dear All,
I'm fairly Sure that Cold Fusion isn't as difficult as it seems??
Does anyone else agree??
Hope not to unlock Pandora's Box in Every Single re-incarnation!
Regards,
SBGB
All Best Wishes
Related to Does the fusion process cause a chain reaction?
1. What is the fusion process?
The fusion process is a nuclear reaction in which two or more atomic nuclei combine to form a heavier nucleus. This process releases a large amount of energy, similar to the process that powers the sun and other stars.
2. Does the fusion process cause a chain reaction?
Yes, the fusion process can cause a chain reaction under certain conditions. In order for a chain reaction to occur, there must be enough energy and pressure for the nuclei to overcome their natural repulsion and fuse together. This can only happen at extremely high temperatures, like those found in the core of the sun.
3. What elements can undergo fusion?
The elements that can undergo fusion are primarily light elements, such as hydrogen and helium. These elements have relatively low atomic numbers, making their nuclei easier to combine and release energy.
4. Is the fusion process safe?
The fusion process itself is considered to be safe as it produces little to no radioactive waste. However, the high temperatures and pressures required for fusion to occur make it difficult to control and harness for practical use. Currently, fusion is not a viable source of energy for everyday use.
5. How is the fusion process different from fission?
The fusion process is the opposite of fission, which is the splitting of a heavier nucleus into smaller nuclei. While fission releases energy by breaking apart atoms, fusion releases energy by combining atoms. Fission is used in nuclear power plants, while fusion is still being researched and developed as a potential source of clean energy.
  • Nuclear Engineering
  • Astronomy and Astrophysics
