Estimating the Probability of Nuclear Power Plant Damage from Rare Tsunamis
The discussion centers on calculating the probability of damage to a nuclear power plant from a rare tsunami, estimated at 1 in 200 years. The probability of no damage is expressed using the exponential function, leading to a calculated probability of damage of approximately 0.259. Participants debate the correct application of failure rates and the relevance of the provided rate in the problem statement. The consensus indicates that the exponential function is necessary for accurate calculations. Ultimately, the correct probability of damage is confirmed to be around 0.259.
hworth
The frequency of a tsunami large enough to threaten the safety of a nuclear power plant has been estimated to be 1 in 200 years. If the plant’s life is 65 years what is the probability it will be damaged by such a tsunami? What is this probability more commonly termed?
[2 Marks]
How do you get a base event failure rate for components with no recorded failures in an operating time T? Let λ = k/T. A Pessimistic Failure Rate λ = 1/T is known as ‘one tomorrow’. A PSA could use k = 0.5525 (For the estimation of failure rates for low probability events see Progress in Nuclear Energy 4 374-476 1997).
Probability of no damage = e-λT
λ = 0.5525/200
Probability of damage = 1-e-(0.5525/200)(60) = 0.153
A pessimistic failure rate λ=1/T is known as 'one tomorrow'.
Is this correct or completely wrong? Thank you
You are overthinking this. The problem statement gives you the rate. Where this number comes from is a different question not relevant here.
Are you sure? So would you say 0.325? Seems too simple.
You'll still need the exponential function.
Do you get 0.259?
λ = 1/200
Probability of damage = 1-e-(1/200)(60) = 0.259
That's how I would answer the problem.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
