Number Theory Euclidean Algorithm
MathSquareRoo
Suppose that u, v ∈ Z and (u,v) = 1. If u | n and v | n, show that uv | n. Show that this is false if (u,v) ≠ 1.
a | b if b=ac
3. The Attempt at a Solution
I understand this putting in numbers for u,v, and n but I don't know how to formally write it.
Do you know a relation between the gcd and linear combinations of u and v?
Linear combination of u and v are equal to the gcd correct? And the gcd divides u and v I believe. I need help organizing all these ideas.
Not necessarily true for an arbitrary linear combination, but there exists at least one linear combination equal to the gcd.
Certainly, gcd means greatest common divisor, so it's certainly a divisor.
OK, if we let d = the gcd, then you know there is a linear combination such that d = au + bv. Now you know that u divides n and v divides n, so how can you use that fact here?
So then au divides n and vb divides n?
No, that isn't necessarily true. However, if u divides n, then n = ur for some integer r. And v divides n, so n = vs for some integer s. Now try using these facts.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
