Objects on a Slope - Pretty Easy
  • Thread starter Thread starter bobber205
    Slope
The discussion revolves around a physics problem involving two masses on a 60-degree slope. The user hypothesizes that a larger mass is needed on the right side to create positive acceleration down the slope. They present a force equation but arrive at an incorrect mass calculation of 1.86 kg. Confusion arises regarding the setup of the problem, particularly whether the objects are connected by a rope. The need for clearer problem presentation is emphasized, highlighting the importance of clarity in physics discussions.
bobber205
Objects on a Slope -- Pretty Easy
This is a modified version of a physics problem for my HW. We were to find the mass an item had to be to "go down" a slope and go up. However, the slopes were not even so a larger mass one side did not necessarily mean the "heavier" side slid down.
So I made another problem where they were even. In this case it was 60 degrees.
The slope is 60 degrees. The mass on the left Fl is 2.1 kg. My hypothesis is that a larger mass is required on the right to make the right "go down" or have a positive acceleration. Correct?
Here's my Force equation.
Ftotal = Fl + Fr.
I picked a random number, .64 m/s2 for the right acceleration to be.
sin(60)(.64)m = (9.8)m + sin(60)(2.1kg)(-9.8)
which leads to m = 1.86 kg, which is obviously wrong!
Where did I go wrong? If I solve for a negative acceleration, I at least get a number less than 1.86 which makes logical sense at least. Any ideas on what I did wrong?
Are the two objects connected by a rope or something?
Your "presentation" of the problem is very vague and confusing.
You probably know very well what is it about (I hope) but you cannot expect other people to guess your mind.
This is a physics forum (and not psychic forum).
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
