Oblique Elastic Collision Angle Calculation
To solve an oblique elastic collision problem, it's essential to apply the conservation of momentum and energy principles. In the scenario with two identical marbles, one moving and the other stationary, the initial marble continues at a 55-degree angle after the collision. A vector diagram is crucial for visualizing the momentum conservation equations, as momentum is a vector quantity. By combining the equations for momentum and kinetic energy, the angle between the directions of the two marbles can be determined. Understanding these concepts is key to solving similar collision problems effectively.
kingjoshie
I am unsure about how to go about solving an oblique elastic collision question, I understand that momentum is conserved and how to calculate momentum but unsure as to how to calculate the vectors.
The question is : A 45g marble collides with an identical stationary marble, and continues at 55 degrees to it's original direction. The collision is perfectly elastic. What is the angle between the direction taken by the target ball and the original direction of the incident ball?
p=mv, not too sure how other equations are set up.
I calculated the force of momentum of both the balls and the direction but drew a total blank.
Momentum is conserved. Write a momentum conservation equation, realizing that momentum is a vector. (Hint: Draw a vector diagram illustrating that equation.)
The fact that the collision is elastic will give you another conservation equation. Combine those two equations to figure out the angle between the final velocities of the marbles.
Hi, Thanks a lot, I was having a hard time understanding that part but you definitely cleared it up.
