Observing galaxies: area of sky would I need to survey
The discussion revolves around calculating the area of the sky needed to survey in order to find a specified number of elliptical galaxies, given certain parameters such as the number density of galaxies and the magnitude limits of a telescope. The subject area includes concepts from astronomy and cosmology, particularly relating to volume and solid angle calculations.
  • Participants discuss the application of equations to determine distance and volume based on magnitude. There are inquiries about how to relate the calculated volume to the area of the sky that needs to be surveyed. Questions arise regarding the appropriate units for reporting the answer and how to express the required area in terms of solid angle.
Participants are actively engaging with the problem, exploring different aspects of the calculations. Some have provided numerical values and attempted to derive relationships between volume and solid angle. There is a collaborative effort to clarify how to express the area needed in terms of solid angle, with no explicit consensus yet on the final approach.
Participants are working under the assumption of a specific number density of galaxies and the limitations of the telescope's magnitude. There is an ongoing exploration of how these assumptions affect the calculations and the interpretations of the results.
Cedric Chia
Given that there are 10-2 Ellipticals per Mpc3 and my garden telescope can reach to 14 mag. How large an area of sky would I need to survey to find 100 Elliptical galaxies ? (assume the typical absolute magnitude for an Elliptical galaxy is -21 mag).
d=100.2(m-M-25)
n=N/V
by substituting m=14 and M=-21 into the first equation I found d=100Mpc,
which indicates the volume of sky I could possibly observed is 4/3⋅π⋅d3 = 4188790 Mpc3,
using the second equation n=N/V , where n=number density, I have 10-2 = 100/V,
thus V=10000Mpc3, which is the volume I need to observed to find 100 galaxies.
with these values, how can I find how large the area of sky I need to survey?
d=100.2(m-M-25)
n=N/V
You have almost finished... What units are you going to use to report your answer (solid angle, fraction of the hemisphere sphere...)?
How can I find solid angle relative to the 10000MPc3?
The solid angle for a whole sphere is 4pi...for half sphere 2pi...how much of the sphere do you need to view?
Thank you for the quick reply,
the total volume of the sphere is 4188790 Mpc3
("which indicates the volume of sky I could possibly observed is 4/3⋅π⋅d3 = 4188790 Mpc3")
and the volume I need to view is 10000Mpc3
("thus V=10000Mpc3, which is the volume I need to observed to find 100 galaxies")
with these values how can I find solid angle?
What fraction of the total sphere volume do you need to observe?
I think that would be (volume I need to observe) / (total sphere volume) = (10000) / (4188790) = 2.39⋅10-3
  • · Replies 72 ·
10K
  • · Replies 16 ·
