Odd constraint problem: Reflected and Transmitted Power of String
The discussion revolves around a problem involving the reflected and transmitted power of a constrained string, where the deflection and its gradient are continuous at a specific point. The equations derived suggest that all incident power is reflected, leading to a contradiction when trying to satisfy both continuity conditions. Participants express uncertainty about the assumptions made regarding the general solutions for the waves, questioning whether they adequately account for the constraints imposed. The conversation also touches on the implications of having incoming waves from both directions, which complicates the analysis of reflected and transmitted power. Ultimately, there is a consensus that the problem may not make sense as posed, and further clarification from a supervisor is deemed necessary.
N00813
Given that a string is constrained such that dy/dx = 0 at x = 0 and unconstrained otherwise, what is the reflected and transmitted power?
y is the deflection of the string from the x-axis. y_1 is incident wave, y_r is reflected and y_t is transmitted.
Reflected power, transmitted power have already been derived in terms of impedances.
Impedance Z = \frac{Driving Force}{string element velocity}
Continuity of y and dy/dx.
Knowing that y and dy/dx are continuous, I wrote \frac{\partial y_1}{\partial x} +\frac{\partial y_r}{\partial x} = \frac{\partial y_t}{\partial x} =0 at x = 0.
Substituting in the general solution y_1 = e^{-ikx+iwt}, y_r = re^{+ikx+iwt}, y_t = te^{-ikx+iwt};
I got 1 + r = t and 1 - r = t = 0 at x = 0.
The latter suggests all reflection, no transmission, which isn't correct because it doesn't satisfy the first equation.
It does not satisfy which equation precisely ?
The given constraint (and continuity of gradient) means that -ik(1-r) = -ik(t) = 0.
Continuity of string means that 1 + r = t.
If t = 0, then 1-r = 0 so r = 1. But then 1 + r = 2 =/= t = 0.
Yes, so there must be something wrong at a more elementary level: even if you only impose continuity of y and dy/dx on these "general solutions" you end up with r = 0 ! This way you have three equations with only t and r as unknowns. Are you sure the y are general enough ?
I know the string satisfies a wave equation. Evanescent waves would be my next guess, but beyond that I'm stuck.
The solution for that problem requires incoming waves from both directions at the same time. (producing a standing wave with an anti-node at the origin)
There'd be no reflected and transmitted power then, would there? Since the wave is standing?
Good point. I'm not sure what to make of that. The question doesn't seem to make much sense since there is incoming energy from both ends.
Earlier in the question, it did say to use a complex exponential for y (=A exp(ikx-iwt)) to prove that time-averaged power = 1/2 Zw^2 A^2. I assumed that carried forwards.
I suppose I'll have to ask my supervisor for this, then. Perhaps the answer really is zero.
