Does Oil Viscosity Impact Low Temperature Stirling Engine Performance?
Oil viscosity significantly impacts the performance of low temperature Stirling engines, with some designs recommending against oiling the working piston due to potential friction issues. The discussion highlights a specific design that suggests no oil should be used, while another design advocates for a thin coat of oil. Users express concerns about the effects of oil thickening over time and its ability to attract dust, which could hinder performance. The engines discussed are primarily seen as educational tools rather than high-performance machines, with one user planning to build a model to better understand Stirling engine mechanics. Ultimately, the debate centers on finding the right balance of lubrication to optimize engine function without introducing excessive friction.
MacLaddy
I have been doing a bit of research on building a low temperature Stirling engine, and I came across this website,
http://heetgasmodelbouw.ridders.nu/Webpaginas/pagina_koffiekop_jan/koffiejan_frameset.htm
The design on this website looks nice, and I would like to give it a go (after I build a simpler model), but I have my doubts about the following statement within the instructions.
Never oil the working piston in the cylinder! Even very thin oil is more or less viscous and increases the friction. Mind that the power of this type of Stirling models is very low so little friction can be fatal.
Any thoughts on this? I understand oil could be a bit viscous, but it wouldn't seem to be so dramatic that you would want to run this engine dry.
*EDIT* Be sure to hit the "English" button at the very top of the webpage.
It looks cute, but the RPM is unimpressive, to say the least, as those props want to turn around 5-6 thousand rpm to generate any appreciable thrust.
Well, I don't believe it's designed to be anything more than a toy. I personally want to build it just so I can get a better understand of the inner workings of a Stirling. Plus, it runs on a coffee cup. I mean how cool is that?
I will be starting to build this one in a day or so,
http://www.physics.sfasu.edu/astro/courses/egr112/StirlingEngine/stirling.html
but I am still curious about the "To oil, or not to oil" situation. This one calls for a thin coat of oil, whereas the other one says not to use it.
oil can have a significant effect on mechanical performance. even a very light oil will slowly thicken over time, grab dust from the air, and change with humidity. Thats why most dial gauges, watches, and other precision mechanicals use no oil. In some of our precision pneumatic equipment, just the residual oil from a finger will prevent its function.
nice links, but the english conversion didn't change the main text
(I was bummed...looks interesting...must learn dutch now...lol)
dr
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
