TSny
- 4,810
I'm not following you here. Maybe you're thinking of a different "loaded beam" scenario. In the three-particle model of post 147, the beam lies along the x-axis (boost axis). The beam cannot be twisted into a helix by a boost along the axis.pervect said:This simple straight loaded beam will be twisted into a helix when one does the appropriate Lorentz boost, so I assume that some of the results for helices (which I haven't had the time or inclination to look at in detail) will still be applicable using the simpler "loaded beam" variant of the problem.
Yes, I agree.I believe the beam must have a finite width to support the loads with finite stresses.
Yes, I think that's true. As Peter has pointed out, this would violate a postulate that the energy density must be positive in all frames of reference. In the case of the three-particle model, we can avoid the problem by simply allowing the rod to have mass. I initially chose a massless rod in order to make the "paradox" more dramatic. But we can add mass to the rod and the motion of the system will still appear paradoxical in the boosted frame in which the three masses are all lined up on the same side of the rod.I believe that an analysis based on the stress-energy tensor will show that sections of the beam under tension (in the direction of the boost) will have a negative energy density in the boosted frame, and sections of the beam under compression (in the direction of the boost) will have a positive energy density.
If the boost is along the x direction, then the stresses Tyy and Tzz in the rest frame will not matter. But the shear stresses, such as Tzx are important in resolving the paradox.I don't think the stresses in the directions transverse to the boost should matter.
In the three-particle system, the rod is along the x-axis. So, at first, you would think that it cannot contribute to angular momentum of the system. However, calculations show that the shear stress in the rod actually does contribute to the angular momentum of the system in the frame in which the particles are lined up. These contributions combine with the angular momenta of the particles to produce a total angular momentum of the system that has only an x-component and remains constant in time. This is consistent with zero torque acting on the system.Because the beam will no longer be massless, in the boosted frame, the beam's contribution to the angular momentum must be evaluated, and I expect it will explain the "paradox".
