Oopsy on a Test Problem - Acceleration
  • Thread starter Thread starter rockmorg
    Acceleration Test
The test question involves a horizontally launched projectile with an initial speed of 50 m/s. The key point discussed is that while the projectile moves horizontally, the only acceleration acting on it is due to gravity, which is 9.81 m/s² downward. There is no horizontal acceleration since the projectile maintains its horizontal speed unless acted upon by another force. The discussion also highlights the importance of knowing the initial height to determine if the projectile has hit the ground, which would affect the acceleration. Understanding these concepts clarifies the relationship between horizontal motion and vertical acceleration in projectile motion.
rockmorg
I had a test question that went like this:
Projectile is launched horizontally with an initial speed of 50 m/s. It started from rest, what is the acceleration after 3 seconds?
For the life of me I couldn't come up with a velocity final or distance to find the acceleration, is there something I forgot that happens on Earth when a projectile is fired horizontally?
Make sense, anyone?
Thanks!
well, assuming you are on earth, there is no air resistance and the projectile hasn't hit the ground yet, the acceleration is going to be 9.8m/s^2, because the only force acting on it is gravity.
But isn't it only going horizontally? so the acceleration would be in the y direction, and this is x...
Were you given an initial height?
"But isn't it only going horizontally?"
It was launched horizontally- it certainly won't keep going only horizontally!
Assuming again that this was done on the surface of the earth, that you are ignoring air resistance and that the object has not yet hit the ground, the only acceleration (NOT velocity) is 9.81 m/s2 downward- there is NO horizontal acceleration.
eep asked if you were given an initial height because of the possibility that the projectile would have already hit the ground- in which case there would be NO acceleration at all!
