Powering an OpAmp with Dual Batteries: Ground-Free Circuit Design
Powering an operational amplifier (OpAmp) with dual batteries can be achieved without a connection to mains ground by designating the junction of the batteries as the reference point, effectively creating a bipolar source. The concept of "ground" in circuits is arbitrary, and it's crucial to understand that voltage is relative, allowing for flexibility in defining reference points. Discussions highlight the importance of avoiding floating inputs to ensure stable operation, emphasizing the need for a common potential, typically at the midpoint of the power supply. Additionally, while some OpAmps can self-bias without DC feedback, good design practices recommend providing feedback to maintain consistent performance. Ultimately, understanding the internal circuitry of the OpAmp can influence design choices, especially regarding feedback requirements.
Rudinhoob
How to power an OpAmp using two batteries, so there's no connection to mains ground or neutral? This circuit requires ground to force the node connecting the batteries to be at zero potential. How can I achieve the same result without grounding?
thanks.
One end of the load connects to the output of the op-amp and the other end of the load has to connect to the node between the two batteries. The inputs may or may not be referenced back to this node depending upon configuration. What else you connect that node to is up to you. Did you think it is impossible to use op-amps in cases where there is no connection available to the Earth such as in airplanes, cars/trucks, and portable devices?
I'm pretty sure they can be used without Earth connection. What confused me really that many texts show the dual power supply using batteries with a connection to earth, which makes no sense.
But how using two power sources is different than using one? Cannot just combine both into one source?
"earth" is often just another word for "ground".
There are sometimes sublte differences in how the words are used (especially when dealing with equipment connected to mains, or for interference/shielding); but in from a theoretical point of view Earth is just a convenient place to ground to your circuits.
It is important to understand that the ground point in a circuit is just an arbitrary point in a circuit, where we DECIDE that the potential (voltage) is zero.
Now, if you connect to batteries is series (- + - +), and choose the ground point to be the connection between them you will find that you've created a bipolar source.
Are you referring to "reference node"? If so then this has no physical impact on circuit it's merely used for calculations.
Not sure what do you mean by "bipolar source" I thought every source is bipolar with + and - poles.
Terminology, terminology...
I see nothing on your sketch requiring a connection to "Ground".
"Circuit Common" is a better term than "Ground" because it does not imply "Earth".
Simply take your eraser and remove that wire between the three-line "Ground" symbol and the junction of your natteries. In fact, erase the "Ground" symbol too.
Then hook your voltmeter's black wire to that battery junction.That'll do it.
Put a big round dot where the batteries join if it makes you comfortable.
Get over the notion that "ground" is magic. It's just another wire.
Is the inverting configuration on the left valid? What makes it different than the one on the right?
Yes.
On right: The + input of your opamp is not tied externally to any point of reference, so it'll find its own according to whatever is just inside the triangle representing the opamp.
Some opamps will self bias satifactorily, some won't.
When running a dual supply opamp from a single supply as you show, it is usual practice to create a reference of ~ Vsupply/2, perhaps by placing two equal resistors in series across the supply and using their midpoint as reference.
EDIT late addition... in yuor right hand circuit you'd use the reference thus formed, Vsupply/2, as signal reference point and connect the opamp's + input there.
That is an interesting application for self-biasing single supply audio amplifiers like the LM383(TDA2002) - its output is biased halfway between V+ and V- . So it makes a good reference for dual supply opamp circuits because it'll absorb or deliver substantial current.
Have fun
old jim
I am not sure what you mean by "physical impact". The point is that voltage is relative: it is always the difference in potential between two points. Hence, it is perfecly valid to assign "V=0" to whatever point you want in the circuit and call that point ground as long as you are consistent. An obvious example would be a circuit with voltage source (lets say a12V source ) where the negative terminal is often assigned to be ground. However, from a physical point you could also just say put ground at the positive terminal, in which case the negative terminal would be at -12V.
Note that this also has practical implications. It is e.g. why you can amplify an AC voltage using a circuit with only one battery; as in your circuit above.
No, a bipolar source means a source where one terminal has a potential lower than ground (i.e. it has three terminals: plus, ground and minus).
Yes, that's the way to do it, basically.
It is not good practice to let inputs 'float', the way they are doing on the right hand diagram. A good OP Amp will have a certain amount of 'common mode rejection' and will not mind too much where its signal inputs lie with respect to the supply volts; it will do its best to amplify the voltage difference. However, there is always a possibility that, somewhere in the signal paths, there will be a 'stray connection' to pull the inputs one way or another, via some very high resistance path to one or other of the 'rails', which will limit the output current available and, thus, the feedback will stop working.
It is much better to provide a common potential, somewhere near the mid point of the power supply rails, to give the OP Amp the best chance of working properly.
If you use the left hand arrangement and find the circuit doing what you want and then suddenly disconnect that mid-point (bias) line, it can work fine for hours until things drift and take you totally by surprise. This can also happen at switch on.
There is a good principle in electronics and that is to 'define' the operating conditions of all devices and don't let anything 'float' if you can help it. (That goes for logic gate inputs, too.)
You could view it as a single power supply with a centre tap. http://physicsforums.bernhardtmediall.netdna-cdn.com/images/icons/icon6.gif
The point about having two power supplies and a 'ground' is that the 'mid point' is at the same potential as it would be in another different piece of equipment, with different voltage supplies, would have the same ground reference. A distinct advantage.
And the ground of this "bipolar" battery has to be connected to "ground" or "earth"? or can be connected to what point in the circuit?
In most circuits this midpoint (or "centre tap" as NascentOxygen called it) IS the ground, i.e. everything else that should be at zero potential is connected to this point.
It can be connected to anywhere you like but choosing the same point for all your equipment makes sense and a common connection between all circuits on one board, all circuit boards in a rack / unit, the equipment case and (but not always) the mains Earth is pretty common. From your questions, I gather that you don't have a lot of actual hands-on experience of this stuff. Once you do, you will find things make much more sense.
The point about using a bipolar supply is that your signals can go positive and negative and the amplifier can handle them much easier. It is not so important for RF circuitry where the signals are usually fed through series capacitors and the actual DC voltage is not relevant.
The diagram on the right cannot work. There really is no feedback path. It appears that there is, but when the inverting input is pulled in a direction by the resistor network coming from the output, there is nothing that is keeping the non-inverting input from following it by the same amount. The non-inverting input needs to be 'held' to something as it is in the schematic on the left.
By George, you're right. No explicit DC feedback - as I was hinting in post 10.
Do I need to consider the internal circuitry of the OpAmp?
No. That's the beauty of an OP Amp. You can assume that it produces a massively magnified version of the difference between the two inputs (thousands of times). Different manufacturers often make their version of the generic Op Amps differently - they just do what the spec says they should. You just drop it into a circuit with the right operating conditions and it will behave ' perfectly' if you stick to the frequency and load limits.
Open circuit gain is treated as infinite for many applications.
You should not need to consider internal circuitry for the examples that you gave from the standpoint of whether the circuit will work at all or not. Of course you need to know enough about the device to know that it is a bad idea to use feedback resistors that are in the 100 Megohm range or in the less than 10 ohm range. Do you understand more than when you first posted in this thread? We are here to help!
Then how could you tell the circuit on the right does not have "real" negative feedback?
Good circuit design means you don't leave things up to chance, so in a respectable design you'd provide DC feedback as the fellows are saying.
I was probably remiss in not pointing out that self biasing opamps are the exception rather than the rule..
The LM386 for example is a small audio amp that can work withpout DC feedback..
But it's not a general purpose opamp instead it's made for AC signals. So its designers removed the need for DC feedback.
old jim
Can you see any DC feedback which would keep the output at mid rail? If you can't see it then you have to assume it's not there and you have to provide your own. If it had some vestigial bias, it could be either way.
Then this DC feedback is OpAmp type dependent, which means it has to do with the internal circuitry. Although not necessarily exposed in the analysis, it seems that there are some decisions that are dependent on this and to justify them, we need to include the details of the OpAmp in analysis.
I wouldn't put it that way. You asked a question about Op Amps and not about specialist circuits that are aimed at a particular application. Read up something about the characteristics of an OP Amp and you are unlikely to find any mention of internal DC feedback. The LM386 is not sold as an Op Amp. Why are you looking for loopholes here?
I see. :)
There is no AC feedback concerning the circuit in question either.
I think it would be correct to say for linear opamp circuits that feedback is applied to the inverting input rather than to non-inverting... Nonlinear circuits like comparators employ positive feedback.
The premise of a linear op-amp circuit is this:
inverting input will be held equal, by feedback, to non-inverting input.
Designer controls non-inverting(+) input. He arranges a feedback circuit that allows the opamp to hold its inverting(-) input at same voltage.
The circuit in question's noninverting input voltage is undefined, or 'indeterminate'.
The amp will attempt, via that top resistor, to move its inverting input to whatever voltage it finds on its non-inverting input. But nothing locks down that noninverting(+) input, it can be anything. Probably it will be someplace between the power supply rails.
Sophie described that in post 10, and again when he mentioned 'vestigial bias'. S'nova said it in #16.
So right hand circuit suffers more from an undefined input than from lack of feedback.
That's my take on it.
old jim
jim hardy said:
... these old National appnotes were great. TI has re-issued most of them
http://www.ti.com/lit/an/snla140a/snla140a.pdf
Thanks Jim. Here's a "little" something for you.
"www.analog.com/library/analogDialogue/archives/39-05/Op_Amp_Applications.zip"
  • #31
Thanks Don i downloaded and saved.
first one in that series, bottom of pp 1.7 is a note that applies to this thread. I would post an excerpt but it appears to disallow copy & paste.
old jim
  • #32
Yea, it's copyrighted and can't be reproduced without permission from Analog Devices. Good info to have on hand though.
  • #33
I thought it's 0 it it's considered a reference node. This is how it's treated in circuit books, they show the non-inverting input for an inverting OpAmp configuration connected to a common node, using the "ground" symbol, and the same symbol used for the input voltage source's negative rail.
  • #34
I guess that's true. :smile:
  • #35
What AC are you talking about here?
Apparently my simple question could not be answered by "engineers" and when they felt incompetent they start farting crap polluting the thread and adding more confusion in attempt to hide their inability to answer a simple straightforward question.
Moderators, please ban me, I'm not going to open this useless forum anymore or read any replies to me. ;)
F.U
  • #36
In your left hand circuit you connected +input to a definite point, the power supply centertap.
In your right hand one you didn't, you left it to find its own level.
Simply calling it "reference" doesn't make the rest of the circuit respect it.
In the boooks, they don't usually show the power supply. Power supply is used to define 'circuit common' , usually power supply centertap.
For opamps like LM324 which is designed to operate with single supply, they often but not always use power supply negative instead.
I strongly recommend you look into the first article in that Analog Devices link posted by dlgoff.
It was written before op-amp fundamentals became so entrenched we forgot how to teach them. Too many cooks and all that...
old jim
  • #37
Apparently my simple question could not be answered by "engineers" and when they felt incompetent they start ... adding more confusion in attempt to hide their inability to answer a simple straightforward question.
dont give up now you're soooo close to success..
  • #38
F.U
That's a pretty gutsy comment coming from the guy asking the questions. The AC I was talking about is the AC coming from the signal generator you have drawn in your schematic. Plain and simple fact is there is no feedback of any kind in the circuit on the right since both inverting and non-inverting inputs will see the same thing fed back from the output. Op-amp inputs are differential, so when they are treated the same as in the circuit on the right, there is essentially NO FEEDBACK
  • #39
"gutsy"? More like plain rude and juvenile (teenage, no doubt). Voting with his feet is no great loss to PF, I think.
  • #40
hmm There's no path for current through the two resistors, as there is in left circuit.
So the opamp can't develop a voltage across its feedback to oppose the voltage source.
Good thinking guys.
I missed that. duhhh...
This old age ain't for sissies, I tell ya.
