Archived Optics - magnification of a converging lens
The discussion centers on calculating the magnification of a converging lens with a dioptry of D=3. The initial approach led to a magnification of u=-4, which was identified as incorrect due to a misunderstanding of the sign convention for real images. Correcting the sign convention, the relationship between dioptry, object distance (p), and magnification (u) was re-evaluated. The final calculation yielded a magnification of u=4, aligning with the expected result. This highlights the importance of adhering to sign conventions in optics calculations.
matematikuvol
Optics -- magnification of a converging lens
Dioptry of converging lens is $D=3$. What is magnification ##u##?
##\frac{1}{f}=D## - dioptry.
\frac{1}{f}=\frac{1}{p}+\frac{1}{l}
u=\frac{l}{p}
l=up
D=\frac{l+p}{lp}=\frac{p(u+1)}{up^2}
Putting ##d=0.25m##, I get
0.25\cdot 3\cdot u=u+1
and ##u=-4##. Where I make a mistake?
A real image will be inverted (i.e., will have a negative magnification). So, using the sign convention implied by $$\frac 1f= \frac 1p+\frac 1l $$where both ##l## and ##p## are positive for a real image, the magnification ought to be ##u=-l/p##.
Carrying that through gives you $$D=\frac { (u-1)}{up} $$and hence u=4 given D=3 and p=0.25, which I presume was the expected answer.
