Optimizing Shear Stress in Structural Analysis
The discussion revolves around optimizing shear stress in structural analysis through the application of force and momentum equilibrium. The first case can be solved to determine forces F_a and F_b, but the second case lacks sufficient information for a complete analysis. It is noted that removing visible forces could still result in shear on the bolt due to tensions and compressions in adjacent members. An approach suggested involves treating one of the left-side forces as an unknown to express shear values in relation to it. The conversation emphasizes the need for more details to effectively analyze case b.
alexteplyaxins
Determine the largest internal shear force resisted by the bolt.
Apply equibrilium state.
243774
What are the sums of the forces for each case?
I just can solve problem ##a## by apply equilibrium of force and momentum to find ##F_a## and ##F_b##. But with case b, I can't find third equation.
Thank for read
Boom, boom !
Thank for read
Yes, b) is not fully specified. E.g. you could take away all of the shown forces and still have shear on the bolt resulting from tensions and compressions in the members on the left.
You could set one of those on the left as an unknown and find the shears in terms of that, then find the value of the unknown which minimises the maximum shear.
Likes alexteplyaxins
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
