Optimzation problem, only info given are xy intercepts
  • Thread starter Thread starter weirdobomb
weirdobomb
Suppose P(a,b) is a fixed point in Quadrant 1 of an xy-plane and line L is descending in the plane such that P is on line L. Let Q=(xknot,0) and R=(0,yknot) be the x and y intercepts for line L and let
S= 1/(xknot + yknot)
1. Express S as a function of xknot
2. Find any extreme values for S
I know how to do number 2 but number 1 stumps me, how do I get yknot to become xknot?
for 2. quotient rule
so far I have got L=-(y/x) + y using y=mx+b (descending line means it's linear right?)
in another attempt I find the equation of the line using point RP and then PQ then setting them equal to each other to solve for yknot. I use that to plug into S. S would be expressed in terms of xknot and the a and b are constants. If I find the critical numbers of S with this, it comes out very ugly and does not seem like the answer.
HOW DO I APPROACH THIS PROBLEM (it is supposedly an optimization problem).
It's pronounced like "knot" but the word is "nought", which is synonomous with zero.
What does it mean that (a, b) is a fixed point? That's key to this problem.
I think fixed point P(a,b) means that, plug in "a" into equation L results with "a."
I get
S = (x0-a)/x0^2
I get
S = (x0-a)/x0^2
Am I going in the right direction?
Quick question:since x0 and a are points on the graph, is it say to say that the first derivative of S is 0 since they are constants?
If P= (x_0, 0) and Q= (0, y_0) then the equation of the line is x/x_0+ y/y_0= 1[/tex] or y= y_0- (y_0/x_0)x. x_0 is NOT a point on the graph it is <b>number</b>- the x-value of the x-intercept. The &quot;derivative of S&quot;, since it is a line, is the slope of the line, y_0/x_0.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I think fixed point P(a,b) means that, plug in &quot;a&quot; into equation L results with &quot;a.&quot; </div> </div> </blockquote> No, it means that if you put x= a into the equation of the line, you get y= b.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
