Orbital Period and Velocity Question
The discussion revolves around calculating the orbital period and speed of the space shuttle in a 310-mile high orbit. The key formula mentioned is Period = 2(pi)r/v, which relates the period, radius, and velocity. A participant initially struggles to find the period without knowing the velocity but later realizes their mistake. The conversation emphasizes the importance of understanding the relationship between orbital speed and period in satellite motion. The thread concludes with a resolution to the initial confusion regarding the calculations.
Lynn311
The space shuttle is in a 310 mile high orbit. What are the shuttle's orbital period, in minutes, and its speed?
Period = 2(pi)r/v
I can't figure out how to find the period without already having the velocity.
Hi Lynn311, welcome to PF.
There is an expression giving the speed of a satellite at a given distance from the center of the Earth. If you don't remember it, look it up.
I figured out what i was doing wrong. Thank you.
