Orbital Precession Calculation: Unit Explained
In summary: A model in which the total mass ##M## of the solar system, including the sun and planets and anything else considered significant enough, is taken to be at the barycenter of the system, and all of the objects in the system are treated as point masses orbiting the barycenter. Such a model would not be exact, but it would be a reasonable approximation for many purposes.Incorrect. The total mass of the solar system is not at the barycenter. It's more complicated than that.Incorrect.
NODARman
57
TL;DR Summary
Hi, I've just calculated the orbital precession for the earth using the sigma formula of general relativity.
\sigma=\frac{24 \pi^{3} R^{2}}{T^{2} c^{2}\left(1-e^{2}\right)}=\frac{24\pi^3×1.5×10^{11}}{3×10^7×3×10^8(1-0.0034^2)}=0.012
What is the unit of the result? Degrees per century or arcsec?
What are the units of the quantities you plugged in to the formula? The units follow the same relationship as the quantities in the formula.
Likes Vanadium 50
Not correctly since several quantities are squared in the formula but you didn't square them in your calculation.
Likes NODARman
My bad
\frac{24 \pi^3 \times 1.5^2 \times\left(10^{11}\right)^2}{\left(3 \times 10^7 \times 3 \times 10^8\right)^2 \times\left(1-0.0034^2\right)}=2×10^{-7}
But there are no more dimensions.
meter²×sec²/(meter²×sec²)
That's right: the number you get is a dimensionless number. Physically, it represents the fractional precession per orbit.
Likes vanhees71 and NODARman
Is it the angle in radians per orbit? and could be converted into arcsec/century.
Read the second sentence of mine that you quoted in post #6 againl. What does it say?
Hi @PeterDonis
Its just that I recently did a calculation for the precession of Mercury and the formula gave me the angle in radians per orbit. I used: $$\Delta \phi=\frac{6\pi G(M+m)}{a(1-e^2)c^2}$$
Looking at the OP's formula and since $$T^2=\frac{4\pi^2 a^3}{G(M+m)}$$
Then its the same formula which I think gives the angle in radians.
Apologies if by saying fractional precession you mean radians.
Likes NODARman
Sure, in calculation you always use angles in "radians", i.e., dimensionless numbers. I've not seen this formula with ##(M+m)## in the numerator (where does this come from)? Instead of ##(M+m)## the standard treatment gives the mass of the Sun. Then your ##\Delta \phi## is the angle of perihelion precession for one period of the radial motion, i.e., from one perihelion to the next.
Usually the astronomers give the perihelion shift per century. For mercury one century means about 415 periods of its radial motion. So you have to multiply your result by 415 and then convert it to degrees (or rather arc minutes) using ##1^\circ \hat{=} \pi/180 \text{rad}## and ##1^{\circ}=3600''##. The result is about 43'' perihelion shift per century.
Likes LittleSchwinger, DAH, PeterDonis and 1 other person
More precisely, it gives the extra angle in radians, over and above the ##2 \pi## radians that represent one complete circle, that the orbit covers between one perihelion and the next. That's what I meant by "fractional" precession. Radians are unitless (since they represent a ratio of lengths: arc length along a circular arc that covers a given angle, to radius of the circle), which is why the units in the formulas all cancel out.
Thanks for clarifying. I was surprised you didn't say radians for the OP since it would be easy enough to convert to seconds of arc per century as @vanhees71 shows. The OP probably already knew this anyway. :smile:
In my book it gives ##6\pi GM## in the numerator but also states that ##M## is the total mass of the system. I suppose with the Sun totally dominating then just plugging in the Suns mass won't really alter the final calculation. Thanks.
DAH said:
In my book
Which book?
You could use a model in which the total mass ##M## of the solar system, including the sun and planets and anything else considered significant enough, is taken to be at the barycenter of the system, and all of the objects in the system are treated as point masses orbiting the barycenter. Such a model would not be exact, but it would be a reasonable approximation for many purposes.
For a perihelion shift calculation, however, such a model wouldn't necessarily be good enough, because the actual observed perihelion shift of any planet contains contributions due to the perturbations induced by the other planets that are much larger than the GR contribution that we are calculating here. And those perturbations depend on the actual relative positions of the planets, so a simple barycentric model with the total mass at the center won't correctly capture them.
For even more accurate calculations, one could use a framework like the Einstein-Infeld-Hoffmann equations, which also would use a barycentric coordinate system, but which are multi-body equations in which each mass is treated separately. As I understand it, a framework like this is how the perturbations of the various planets on each other are calculated.
For calculating the GR contribution itself, you are correct that it is a good enough approximation to just use the Sun's mass, because it contains the vast majority of the mass of the entire solar system and any GR corrections to the Newtonian effects of the other planets are too small to matter.
I'm not aware of any context where it would make sense to use Newtonian formulas but plug in the sum of just the sun's mass and the mass of one planet.
Likes vanhees71 and DAH
PeterDonis said:
Which book?You could use a model in which the total mass ##M## of the solar system, including the sun and planets and anything else considered significant enough, is taken to be at the barycenter of the system, and all of the objects in the system are treated as point masses orbiting the barycenter. Such a model would not be exact, but it would be a reasonable approximation for many purposes.
Its a level 3 text book as I study part time with the OU in the UK, but its only an introduction to relativity so not advanced GR. I just re read the section on precession and it also states that you can ignore the mass of the planet so there was no need for me to include ##M+m##. The prediction using the formula above for the perihelion advance of Mercury actually matches observation which I think is due to the semi major axis being small and a high eccentricity, but for other planets the formula may not be so precise.
Thanks for the detailed explanation on perturbations from other bodies in the solar system, I will probably look into this sometime in the future once I get to grips on the basics of GR.
All of this is interesting, but it doesn't answer my question. When you're asked for a reference here, the expectation is that you will give the specific reference: the title and author(s) of the book, or paper, or whatever. A web link is also appreciated if applicable.
Likes vanhees71
Yes, to within the accuracy of our observations.
No, those things make the formula, if anything, less accurate. It's just that any theoretical corrections are too small to matter even for the case of Mercury, and are even more so for the other planets.
No, it's even more precise, because the corrections are even smaller.
Likes vanhees71
The book is Relativity, Gravitation and Cosmology.
Author: Robert J.A. Lambourne
Consultant author for the chapter is: Aiden Droogan
You can find it here:https://is.muni.cz/el/ped/podzim2015/FY2BP_KOSM/Lambourne_Relativity__gravitation_and_cosmology.pdf
Chapter 7 page 204
Likes vanhees71
PeterDonis said:
Yes, to within the accuracy of our observations.No, those things make the formula, if anything, less accurate. It's just that any theoretical corrections are too small to matter even for the case of Mercury, and are even more so for the other planets.No, it's even more precise, because the corrections are even smaller.
I think you're right, its the accuracy of the observations that are better for the precession of Mercury.
Likes vanhees71
Not the accuracy of observations, but the size of the effect as compared with the accuracy of our observations (i.e., the minimum effect size that we can reliably detect).
IIRC our observations now are accurate enough to detect the GR precession for all of the planets out to Mars.
Well, arguing with the Newtonian approximation it makes some sense, because the two-body Kepler problem (inclusing the motion of the Sun) is equivalent to the uniform motion of the center of mass and the motion of a "quasi particle" with the reduced mass ##\mu=m_1 m_2/M## moving in the gravitational field of a body with mass ##M=m_1+m_2##.
I'm only not so sure, whether it makes sense to use the Schwarzschild solution for a body of mass ##M## instead of ##m_1## (mass of the Sun) to get a more accurate approximation than just using the Schwarzschild metric with the Sun as the source mass. It's of course a good approximation in our solar system, because the Sun is so much heavier than all planets.
It's different if you consider binary-star systems like pulsars. There you need to use systemat post-Newtonian approximations to the GR two-body problem, which afaik is not exactly solved yet. A thorough discussion of this method can be found in Weinberg, Gravitation and Cosmology (1971).
If you mean plugging in the total mass of the solar system, no, that doesn't make sense, because the mass is not all contained in a single body at the center.
Astronomers doing solar system calculations don't even use the bare Schwarzschild metric with the sun's mass; our measurements are accurate enough that we can see the errors in that approximation (although it's fine for quick and dirty calculations). They use one of several frameworks that allows them to include perturbations from the planets.
Likes vanhees71
1. What is orbital precession and why is it important?
Orbital precession refers to the gradual change in the orientation of an orbit over time. It is important because it can affect the stability and predictability of orbits, and can also provide valuable information about the underlying gravitational forces at work.
2. How is orbital precession calculated?
Orbital precession is typically calculated using mathematical equations that take into account the mass and distance of the objects involved, as well as other factors such as gravitational forces from other bodies and the shape of the orbit.
3. What units are used to measure orbital precession?
The most common unit used to measure orbital precession is degrees per year. However, other units such as radians per year or arcseconds per century may also be used depending on the specific calculations being performed.
4. Can orbital precession be predicted accurately?
While orbital precession can be predicted to a certain degree, it is affected by a variety of factors and can be difficult to calculate precisely. As a result, predictions may have a margin of error and may need to be adjusted over time.
5. How does orbital precession impact space missions?
Orbital precession can have a significant impact on space missions, as it can affect the trajectory and timing of spacecraft. It is important for scientists and engineers to accurately calculate and account for orbital precession in order to ensure the success of space missions.
10K
