Orbital Spin and External Magnetic Fields
ourio
A Hydrogen atom is subjected to a magnetic field strong enough to overwhelm the spin-orbit coupling. Into how many levels would the 2p level split? What would the spacing be in the terms of Bext, e, me, and \hbar
I know that I have to use the gLande equation:
U=gLande\frac{e}{2(m<sub>e</sub>)}mj\hbarBext
I have a feeling that the 2p level will split into 3 levels, but I honestly don't know how to show it.
Any help will be greatly appreciated!
OK... I think I may have got some of it...
The 2p state of hydrogen has \ell=1 with m\ell=-1,0,1
So the 2p state splits into three levels by the external B.
Calculating the gLande factor for the 2p state as \frac{4}{3} and the 1s state as 2, I find that the splitting of the 2p state is only \frac{2}{3} that of the 1s state
SO... the spacing between the levels is:
\frac{e\hbar}{2m}Bext\frac{2}{3}
Does that look right to anybody out there? Help! :-(
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
