Ordinary Differential Equation - tank with inflow and outflo
The discussion focuses on solving an ordinary differential equation related to a tank containing saltwater. The tank initially holds 60 kg of salt in 2000 L of water, with a salt solution entering at a concentration of 0.015 kg/L and a flow rate of 6 L/min. The solution's concentration at time t = 3 hours is derived using the equation C(t) = (65.4/360) - (65.4/360 - 60/2000)e^(-360t/2000). As time approaches infinity, the concentration stabilizes at 0.1825 kg/L.
  • Understanding of ordinary differential equations (ODEs)
  • Knowledge of flow rates and concentration calculations
  • Familiarity with integration techniques
  • Basic principles of mixing solutions in fluid dynamics
  • Study advanced techniques in solving ordinary differential equations
  • Learn about the application of differential equations in fluid dynamics
  • Explore numerical methods for solving ODEs
  • Research concentration and flow rate dynamics in chemical engineering
Students and professionals in mathematics, engineering, and physical sciences who are working with differential equations and fluid dynamics, particularly in applications involving mixing and concentration changes in solutions.
samg1
A tank contains 60 kg of salt and 2000 L of water. A solution of a concentration 0.015 kg of salt per liter enters a tank at the rate 6 L/min. The solution is mixed and drains from the tank at the same rate.
Find the amount of salt in kg at t = 3 hours
Find the concentration of salt in the solution in the tank as time approaches infinity.
My attempt:C(t) = C = The concentration of salt in (kg/L) at time t in hours.
dC/dt = (flow_in - flow_out + 60kg/2000L)
flow_in = (0.015kg/L *6L/min*60min/hour) / 2000L // the concentration that flows in
flow_out = C*6L/min*60min/hour)/ 2000L // the concentration that flows out
2000L dC/dt = (0.015kg/L *6L/min*60min/hour) - C*6L/min*60min/hour) + 60kg
2000 dC/dt = 5.4 - 360C + 60
2000 dC/dt = (65.4 - 360C)
2000/ (65.4-360C) dC = dt*Integrate both sides*Left side :
let u = 65-360C
du = -360 dC
du / -360 = dC
2000/-360 ∫1/u du
(-2000/360) ln(65.4-360C) = t + c // where c is a constant.
ln(65.4 - 360C) = 360t/-2000 + c
e^ln(65.4 - 360C) = e^ 360t/-2000 + c
65.4 - 360C = ce^(360t/-2000)
-360C = ce^(360t/-2000) - 65.4
360C = 65.4 - ce^(360t/-2000)
C = (65.4/360) - ce^(-360t/2000)C(0) = 60/2000 Plug in this to find the constant c
60/2000 = (65.4/360) - c
c = 65.4/360 - 60/2000
C = (65.4/360) - (65.4/360 - 60/2000)e^(-360t/2000)
Got it. We can delete this post!
9K
24K
15K
