Orthogonality of Associated Laguerre Polynomial
Muh. Fauzi M.
I have a problem when trying to proof orthogonality of associated Laguerre polynomial. I substitute Rodrigue's form of associated Laguerre polynomial :
to mutual orthogonality equation :
and set, first for
and second for
But after some step, I get trouble with this stuff :
I've already search solution for this form but still no light. Any body here could help?
The best way is using the differential equation. Write it for ## L^k_n ## and ## L^k_m ##. Then multiply the first by ## L^k_m## and the second by ## L^k_n ##. Then subtract one from the other. Come back if you encounter a problem!
Well I still didn't get it. ## L^k_n ## has a rodrigues form and also associated Laguerre polynomial. Which one I need to use?
I said the differential equation, which is:
## x \frac{d^2 L_n^{k}}{dx^2} +(k+1-x) \frac{dL_n^{k}}{dx} +n L_n^k =0##
Nah... I got it. But still, I am stuck when connecting it with the orthogonality...
I explained it in that post! Just write the equation two times for ## L_m^k ## and ## L_n^k##. Then multiply the first by ## L_n^k## and the second by ## L_m^k ## and subtract one from the other. Then find an integrating factor and multiply the equation by it. You'll find out how to continue but come back if you didn't.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
