Ortogonal subspace proof - Leon 5.2
  • Thread starter Thread starter IntroAnalysis
    Proof Subspace
IntroAnalysis
Let S be a subspace of R3 spanned by the vectors x = (x1, x2, x3)T and y = (y1, y2, y3)T
Let A = (x1 x2 x3 )
( y1 y2 y3)
Show that S\bot = N(A).
Any hints?
Let A = (x1 x2 x3 )
( y1 y2 y3)
Any hints?
Start with some definitions of the terms in this problem. Do you know what S\bot and N(A) mean?
How much do you understand about this problem? For example, what does it mean that S is spanned by those two vectors?
The subspace S spanned by the two vectors means that any vector in S can be written as a linear combination of x and y. This means x and y are linearly independent.
S\bot is the orthogonal complement of S. It means the set w an element of R3 such that wTs= 0 for every s that's an element of S.
The null set N(A) is the set of all solutions to Ax = 0.
There exists z = (z1, z2, z3) orthogonal to x and y.
(z1, z2, z3)^T* (x1, x2, x3) = 0 ; and (z1, z2, z3)^T* (y1, y2, y3) = 0
and the nullspace of N(A) = (x1 x2 x3) * (z1, z2, z3)^T = x1z1 + x2z2 +x3z3 = 0
(y1, y2, y3) * (z1, z2, z3)^T = y1z1 + y2z2 + y3z3 = 0
Therefore, the orthogonal complement of S = N(A)
Does that work? Thanks for your assistance!
Not necessarily. For example, the vectors <1, 1> and <2, 2>} span a subspace of R2 but they aren't linearly independent. This subspace has dimension 1.
You have the guts of the proof, but your presentation is on the clunky side. To show that two sets are equal, show that if u is in the first set, it must be in the second set. The show that if u is in the second set, it must also be in the first set.
So for your problem, assume that u is in N(A). You should be able to show that u is also in S\bot.
Now assume that u is in S\bot. Then show that u must also be in N(A).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
