Oscillation Frequency: Horizontal vs Inclined Plane
The discussion centers on the comparison of oscillation frequency for a mass on a spring when positioned on a horizontal surface versus an inclined plane, assuming a frictionless environment. It is noted that the frequency formula is frequency = angular frequency (w) / 2π, suggesting that frequency remains constant regardless of the surface orientation. Participants clarify that frequency does not depend on acceleration, leading to questions about the specific context of frequency being discussed. The conversation also touches on the dynamic nature of frequency in different scenarios, such as electromagnetic waves. Overall, the frequency of oscillation is considered to be unaffected by the incline in this idealized situation.
n3w ton
How does the oscillation frequency compare when being horizontal and when being on an inclined plane (assuming frictionless).
I thought this:
When on Horizontal surface
frequency = angular frequency (w) / 2∏
Since frequency does not depend on acceleration, the frequency would remain the same?
hi n3w ton! :smile:
n3w ton said:
Since frequency does not depend on acceleration …
why? :wink:
HI,
you are describing frequency in what field exactly ?
It depends on the problem, a Radar EM wave travels with constant speed C , but the frequency is dynamic, it can start at 150 KHz and move toward 450Khz
Welcome to PF!
Hi KHMOU YOUSSEF! WELCOME TO PF! :smile:
My guess is it's a mass on the end of a spring. :wink:
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
