Solving Oscillation Problems with Steel Ruler Measurements
  • Thread starter Thread starter Noiro
    Oscillation
The discussion focuses on solving an oscillation problem involving a steel ruler with a 1 cm amplitude and a frequency of 5 Hz. Participants clarify that the period of oscillation is 1/5 seconds and determine that the path of the ruler's tip over 2 seconds involves calculating the total distance traveled during multiple oscillations. It is established that the tip travels 4 cm in one complete oscillation, leading to a total of 40 cm over 10 oscillations in 2 seconds. The conversation also clarifies the ruler's setup, correcting initial misconceptions about its motion. The final consensus confirms the calculations and acknowledges the contributions of participants in resolving the problem.
Noiro
Steel ruler tip's oscillation amplitude is 1cm, frequency 5Hz. What is the path the ruler's tip goes within 2 seconds?
I think I need to find a period so the equations would be T=1/5 s but I'm not sure.
I don't know how to solve it so I would be grateful if someone could help me.
What does the question mean by "path"? Does it mean the arc length, or the normal deviation, or the tangential deviation?
It is the arc length
Oke doke.
As you correctly say, the period of oscillations is 1/5 seconds. What else do you think we need to work out in order to solve this problem?
Hootenanny said:
Oke doke.
Maybe a phase of an oscillation? I'm not sure though. What do we need?
What do you usually need to work out the arc length (two things)?
Measure of a central angle and radius?
Scratch what I said for now.
Not to interlope, but the arc length is given, and you can't calculate it using the central angle and radius as those are unknowns for this problem.
I think what Hootenanny was trying to steer you towards was the distance traveled per period, try finding that and then try and see what distance the tip travels in 2 seconds.
Correct. So, what is the radius?
No it isn't, the amplitude is given, but that isn't the arc length.
Erm... yes you can.
I don't know. What is it?
You have to work it out...
HINT: If you weren't given the frequency, but were instead given the radius of the pendulum, what equation would you use to determine the period of the oscillations?
I think it's T=2pi sqrt(L/g)
That is correct.
Just one minor point, do you have a diagram associated with this question? I'm assuming that this steel rule is hanging vertically and is oscillating in plane like a pendulum. Would that be correct?
Hootenanny said:
That is correct.
No it's embedded in a clamp. I hope you can imagine what it looks like.
C'mon, get on MS Paint and draw a diagram. A lot of us here are lazy. :shy:
Ahh I see. I had originally envisaged a pendulum-like set up. However, this case actually turns out to be a lot simpler than the case that I had originally envisaged. The steel rule is acting like a mass-spring system and in this case to a fairly high degree of accuracy the tip of the rule doesn't trace an arc. Instead, it traces [approximately] a straight line.
So, let's forget about determining the radius. Instead, can you tell me how far the tip of the rule travels in one complete oscillation?
Well if amplitude is 1cm then I guess it's 2cm. Am I right?
Amplitude is the maximal displacement from the point of equilibrium.
The period is the length of time it takes the particle to return to its initial position, the length of how many amplitudes would a particle have to cover in distance over the course of 1 period?
Another hint:
This little diagram should hopefully make the point a bit more clear:
|---eq---|
--- is the amplitude, not --- ---.
As RoyalCat has said, 1cm is the maximal displacement (i.e. the distance between its equilibrium position and one of the turning points). What is a full oscillation in terms of turning points and the equilibrium position?
So it's 4cm right?
Noiro said:
So it's 4cm right?
Correct. So, if the ruler has a period of 1/5 seconds, how many oscillations occur in 2 seconds? Hence how far does the tip of the ruler travel in 2 seconds?
So in 2 seconds occur 10 oscillations and tip of the ruler travels 40cm. Am I right?
Sounds good to me!
Apologies for the earlier confusion regarding the orientation of the ruler. Thanks to RoyalCat for pointing out the correct set up.
Hootenanny said:
Sounds good to me!
No problem. Thanks Hootenanny and RoyalCat you really helped me!
