Oscillator with equal amounts of kinetic and potential energy
In the discussion about a simple harmonic oscillator, the problem involves determining the displacement from equilibrium where kinetic and potential energy are equal. The oscillator has a spring constant of 5.79 N/m and a mass of 0.828 kg, initially displaced by 3.5 cm. Participants suggest setting kinetic energy equal to potential energy to find the displacement, using formulas for both energies in terms of spring constant and displacement. There is confusion regarding the correct approach, with attempts to incorporate total energy and initial displacement leading to incorrect results. The key takeaway is to equate the expressions for kinetic and potential energy and solve for displacement.
Dwrigh08
If you have a simple harmonic oscillator based on a spring of force constant 5.79 N/m, with an attached mass of 0.828 kg, and the oscillator is initially displaced 3.5 cm from equilibrium, at what distance from the equilibrium point (in cm) will the oscillator have equal amounts of kinetic and potential energy?
I am using Kinetic energy=1/2 mass x omega^2 and Potential energy= 1/2 spring constant x displacement^2 and omega= root of (spring constant/ mass)
My first thought was to set the kinetic energy and pitential equal to each other and solve for the displacement. When I try to do this I end up with 1. My next thought was to take into account the initial displacement and subtract that from 1. Neither work for me. I feel like i am missing an obvious step. Any help would be appreciated.
Can you wright down the expressions for kinetic energy and potential energy for a SHM in terms of k, amplitude and displacement?
I know that total energy= 1/2 k A^2. I tried to solve for total energy and then using E= K+U and rewriting E= 1/2 m w^2 + 1/2 k x^2. I come out with an energy from the first equation and then try to solve for x using the second equation. I don't think that is the right approach.
In SHM, at any instant, the kinetic energy = 1/2*m*w^2(A^2-x^2) = 1/2*k*(A^2-x^2)and potential energy = 1/2*k*x^2
Equate KE = PE and solve for x.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
