Our Beautiful Universe - Photos and Videos
2,456 replies · 337K views
bruha said:
Hi you tell you are from Australia are nt you?:doh:
Yes, I am from Sydney, Australia. I live in the inner west suburbs of Sydney. It is very light polluted. I can only see the brighter stars, I cannot see the Milky Way. To get a better sky view, I load my scope into the car and travel for around an hour out of the city
Astronomy news on Phys.org
Hi fellows, I'm still stuck with my cheap El Crapo telescope, and I used it last night to observe the Moon and also Jupiter for the first time. It was quite fun, since I could see a hint of the different bands of Jupiter, even though the planet appeared quite small in my view. I've never seen that before.
I also got a good view of the Moon with my eyes, and I tried to take some shots of it with a Logitech webcam on which I had removed the lens to use only the image sensor. Now, the telescope ain't exactly Hubble, rather Wobble :oldbiggrin:, since the mount is really bad which makes the focusing very, very difficult.
Nevertheless I wanted to share my photo of the Moon, since it's the best I have taken so far. I filmed the Moon with a tablet, using the software SharpCap which was pretty easy to use and quite configurable. I then used Registax to stack and produce an image, and then I also did some adjustments to improve details.
Anyway, here it is (cover your eyes, professionals! :oldbiggrin:):
And here is "Wobble" with the attached webcam:
When I have more time I will put in some work to do a better mount for the webcam. I am also thinking of modifying the focus mechanism in order to try to make the focusing more easy, if I can.
One of the mentors deleted my previous answer (post) instead of moving it across to this thread when they
moved your one across.
Cannot remember specifically what I said now?? so let's try again 😉
Yes, a steady mount is essential and I suggest that if you really want to make good use of that scope,
you should look at buying something that =isn't going bounce the image all over the place every time
the scope is touched for focussing etc
You could get a mount that will happily handle that scope and maybe a better one in time to come if you
really get enthused and do a scope upgrade.
Still a good effort considering what you were dealing with :smile: keep experimenting
I would also suggest that you do more experimenting with just single images.
You will be surprised with the results that can be achieved !
Stacked images from video frames can produce awesome images but you need a steady platform to begin withDave
Hi,
I got some strange artefact (darker middle spot ) on image of Sirius. ??
And secondly I attach image of Sun take directly (without) filter…-I am not sure if line on lower right quarter could be siluete of sun?
Now I already order solar folie for filter-do you some have experience with it?
Last night was just clear enough to get out and image. Had a really hard time finding anything, but I got a few (integrated) minutes of part of the Virgo supercluster- this is the Markarian chain, with a zoom-in on M87:
Trying to find this, I stumbled upon M53- it's the small near-centered smudge: here's the result of 3 minutes integration time...
probably due to out of focus and you are seeing the shadow of the secondary mirror of the telescope
not a wise thing to do, it can burn out camera sensor etc
Are you sure it was the sun ? looks like blurry craters in there ...
maybe they are out of focus dust spots on the mirror ??
that's good to hear :smile:
don't do any more solar pix without one Dave
I remember you recommended experimenting with single images.
Yes. There are some other problems with the telescope which makes me a bit reluctant to buy a better mount, for instance when I use the star diagonal I can not focus with the eyepieces, since they get just a bit too far away from the focusing point due to a limitation of the focusing mechanism :frown:. I am considering fixing that, if I can, though.
I am considering building a small DIY Dobsonian mount, since it seems to be a quite good design both for targeting reasons and stability, and I watched a couple of youtube videos where people were building mounts. I think it would be fun to do.
Thanks, I will.
Thanks, I will do that.
I took some single images too, and also extracted some single images from the videos I took, and I compared them with the stacked image and the stacked image was only marginally better. I watched the Moon via the computer screen when I was filming, and I noticed 1) a lot of noise artifacts from the camera (at least I think so, and this could maybe be reduced by filming dark frames which I did not do this time) and 2) a lot of noise due to the atmosphere.
Hi @bruha
Sorry, I didn't answer the second part of the question ...
Yes, over the many years I have done many solar white light photos with the basic filter both using
foil as well as silvered glass. I would use these for photographing solar eclipses, Mercury / Venus
transits and for sunspots.
here are some examples ...
lots of sunspots
closeup
Transit of Venus and some spots
solar eclipse ... this image was on the way to totality about 10 mins after this pic
Annular solar eclipse ( where the moon doesn't fully cover the sun - it's a little too far away)
Cheers
Dave
Lets see an example of a single image, generally they will look better than a single frame from a video
unless it's HD video.
The stacking part in Registax is reasonably easy, you of course realize that you get it to only stack the
best ~ 50% of the frames ? ( you probably do 😉 )
It's the processing of the stack that is the tricky part and to be honest, when it comes to solar, lunar
or planetary stacks, I still have a lot to learn to produce a decent result
Stacking and processing deep space single frames is much easier.
1) Don't think they do darks video ... maybe they do ?, I have never heard anyone say such.
2) Atmospheric "noise" is what doing the stacking helps to overcome ... keep your used frame count
to a max of around 50% ... Registax will determine the best frame to use.
2a) ... you will learn that you have to pick your nights ... this also applies to doing solar imaging
(day time, obviously) the atmospheric conditions can vary quite dramatically.
One night, the image can be shimmering lots because of the instability and it's just a waste of time
trying to do anything. Other times not so bad or really steady.
You will be able to judge that by just looking through the eyepiece even before attaching the camera.here's a couple or examples of single shots of the moon ...
The first one using my Canon camera and telephoto lens
This second one is using an astro camera ZWO ASI 1600MM on my Skywatcher 120 x 1000mm
refractor telescope ( image captured in the SharpCap program)
Gosh, the forum software really destroys the image quality 😢
Dennis, if you are interested, PM me and let's swap email addy's or maybe you would be
interested in joining my facebook astro group and see what others are getting up to
By either of those ways at least you / I would be able to send / receive images in their original
quality directly to each other :smile:
Dave
Beautiful photos, @davenn!
I'll be back... :smile:
I noticed I had deleted the single images because they were too bad. :smile:
But I checked with some other images, and the capture via SharpCap was in the resolution 1280 x 960 both for single images and video. The movies were captured in 30 frames/s.
There is one issue I forgot to mention though: I did not use a moon filter, which I should have. This was because I could not fit the variable polarizing filter I've got with the setup I used at the time. And this was just an initial test with the webcam. Instead of filtering, I changed the exposure time and brightness in the software SharpCap instead. Quick and dirty :oldbiggrin:.
Nevertheless I extracted two of the best images from two different movies and here they are
(directly extracted, no modifications and with the original 90 degrees rotation):
I also uploaded one of the original movies to youtube (which youtube probably compressed in some way), but anyway here it is (note that the image is rotated, and wobbles quite a lot, maybe because of small vibrations that traveled through the mount to the scope, I'm not sure):
I never use a filter on the moon. There's really no need to even if the moon is nearing or is full moon.
Just drop the exposure time so that the image isn't over exposed. You are just adding extra glass to the optical path
that will further distort the resulting image
The best times to image the moon and get the most
detail of craters etc is up to and a little past first quarter ... as in my examples above. There's nothing wrong with imaging the
full moon if you just want that, just don't expect a lot of detail as most of it will get washed out in the brightness
yup, exactly :smile:
OK ... now, I'm not sure how much of the blur is 1) the moon motion, 2) the unknown quality of the optics in the scope,
3) the quality of the webcam, 4) focussing or 5) a combination of some or all 4 of the above.
Referring to #2, how does the moon look through the scope visually ... eye to eyepiece ?
Is it reasonably sharp with good detail ? Do you see any colour fringes around the edge of the moon ... like a poor rainbow ?
If it looks reasonably respectable, then the blur can be put down to the other 3 things ... motion, focussing, camera.
Registax ( or any other stacking prog) will really struggle to stack a set of images that are moving across the field of view ... seriously! :smile:
And then on top of that other vibrations
This is where my comments on a solid mount become apparent ... You will see those comments in this thread and any other one where
people are struggling with imaging ... I really cannot stress it strong enough ! :smile:
There's no point having a $2k scope on a crappy mount and even a very good mount will make a middle of the road scope perform well.
Hence my comments a few posts back ... spend money on a decent mount, even if it is just for this current scope ...
at least you will have a decent mount for a better scope in the future
Other big advantage of a decent mount is that it will be one you can do tracking with it, as all the respectable ones come with different
tracking speed settings, eg ... Solar, Lunar, sidereal ( for tracking deep space objects ( galaxies, nebula etc)
This is because the sun, moon and stars all move at different rates across the sky.
Dobo's are great, do a decent one with say an 8" mirror, don't mess around with anything smaller ...6" or less ... will lead to disappointment
Keep in mind with a dobo, you will still have no tracking and you will need to confine imaging to single very short exposure single shots
Most scopes on dobo mounts are Newtonian reflectors and generally low f-ratios, eg f4.5 to around f7 and that tube could always be
transferred to a tracking mount at a later date :biggrin:
OK that will do for this post ... a pretty long spiel haha
Will let you digest it and make any comments/questions Dave
Hi and thank you very much for answer and images-it looks very interesting -is there some difference in filtering function between foil as well as silvered glass?
Lot of succes hi
I did some more "mobile astrophotography" a couple of days ago, that is, photographing the sky with only a mobile phone (LG G4), like I've done before.
Date: 26 April 2019.
Stacking software: DeepSkyStacker.
Detection software (online): Astrometry.net.
Big Dipper/Ursa Major:
(20 stacked photos, ISO 800, f/1.8, 4 seconds exposure per photo (if I remember correctly))
With more contrast:
I also took some photos by putting the phone on a flat surface, pointing the camera straight up into the sky:
Detections by Astrometry.net:
I also took multiple sets of photos, trying to make a larger image by making a panorama.
I have however not been able to make this work, since none of the software I have tried has been able to stitch photos with merely stars in the photos. I have also searched for specialized software for this job, but I haven't found any, so I don't know if this is possible at the moment with available software. If anyone knows more about this, I would very much appreciate information about it :smile:.
And here's another photo from my observation point out on a beach:
(1 photo, ISO 800, f/1.8, 15 seconds exposure)
Thanks for your support, @davenn! I will digest it and reply with more details later. I have got a better a tripod now (which can be elevated to about 1.5 meters), and I also have managed to make it more stabile than it was. I'm working on doing a mount for the scope on it. :smile: And I have got some ideas I will try to improve the focusing mechanism.
I found a https://live.staticflickr.com/65535/47681612592_63286714b4_c.jpg today at a second hand store for $10, and I took it out with the scope to the park today, since I was going to try to take photos of the Sun (with a sun filter mounted in front of the scope). I set up the tripod at a good place and looked around for my bag with filter, eyepieces and camera mount. But it wasn't there, I had forgot the bag at home :oldbiggrin:.
We have very clear skies here at the moment, and I am thinking of going down to the beach tonight to try out some things...
nice find :smile:
Nice photos! I use Hugin to stitch panoramas (astro and otherwise), with astro pics I usually have to manually identify 'control points' for the stitching algorithm.
Andy Resnick said:
Nice photos!
Thanks!
Oh, I forgot about Hugin, if I remember correctly you suggested it before to me. I will definitely try it out in a couple of hours.
Last night I actually got a lot of good photos, including a large 360 degree panorama with stars, where I used the city skylines, beach and other things as a "base" so the stitching program could handle it. I also filmed Jupiter moving, a first time for me! I will post the best things when I am done processing (I captured about 14 GB of stuff :oldbiggrin:).
Here's a recent result of stitching- a portion of the Virgo supercluster, followed by a small 'Rogue's gallery'. Individual images were acquired over the past 3 years, each night's viewing was stacked into a 'substack'. Acquisition times on each substack are about 1 hour@ 400/2.8, ISO 1000. Three primary fields of view were then assembled from substacks after stretching, denoising, and background subtraction (the lines are artifacts produced by non-identical fields of view), the three 'superstacks' were then stitched in Hugin. Images are a bit larger than usual...
Lot of succes hi
Not much really. the silvered glass often has a colour filter in it so the result will be a yellow to orange appearance.
The mylar film filters tend to have a bright blue colouring
Hi, thank you for answer,
hope, today I will try solar filter, (but when I produced solar follie piece unfortunately small middle hole (from compasses) was made -do you think it is problem?
thank you and lot of succes
yes, it is a problem 😕
You have to treat filters very carefully. Store them in a cardboard box so that nothing touches/damages the front or back sides of the filter.
This goes for mylar or glass filters.
Is your filter a glass type or mylar film type ?
if it is a glass one, use a black marker pen ( texter) to cover over the scratch
But by your comment, I'm assuming it's a mylar type. I have used a small bit of black tape over a hole/mark in an urgent situation ...
Away from home and unable to make a new filter.
Show me a photo of the filter so I can see what you are dealing with :smile: Dave
Hi and thank you for answer,
filter is Baader astrosolar safety film 5.0 and I attached photo of filter,.
242855
Here is the large 360° panorama (resized here to appropriate forum width) which is a combination of 25 photos, ISO 50, f/1.8, but I don't remember the exposure times which for some reason weren't saved in the photo info. There are stars in the picture, but they are only visible in the large photo versions (see photo links below).
Info (from left to right):
------- Turning Torso --------------------- Malmö ---------------------------- Øresund Bridge -- Copenhagen ---
Larger versions are here, and darker versions are here and https://www.flickr.com/photos/132956507@N08/46973326824/sizes/l.
Copenhagen was definitely observed when doing this measurement, so I think I collapsed the wavefunction of the city.
I will post a short clip of Jupiter moving in my next post, when it has been uploaded to youtube.
We have very clear skies here again today, so I will probably try some more stuff tonight! :woot:.
  • Love
Jupiter moving in my telescope:
