How Do You Calculate the Coefficient of Kinetic Friction on a Ramp?
  • Thread starter Thread starter crcowboyfan
    Friction
To calculate the coefficient of kinetic friction on a ramp, the problem involves a 75 kg box sliding down a 25-degree incline with an acceleration of 3.6 m/s². The force of gravity acting on the box is determined, and the normal force is calculated using the cosine of the angle. The net force equation is set up, incorporating the gravitational component down the ramp and the frictional force opposing the motion. The coefficient of friction is ultimately found to be 0.061, which matches the book's answer. The discussion highlights the importance of understanding force components and friction in solving such physics problems.
crcowboyfan
1. A 75kg box slides down a 25* ramp with an acceleration of 3.6 m/s^2
a. Find the coefficient of kinetic friction between the box and the ramp
b. What acceleration would a 175 kg box have on this ramp?
Fg = (weight)(gravity)
I started to try to find the force of gravity and the x and y components, but got confused on where to go from there
Best way i found to start any questions with forces is a FBD/sketch, then bulid it up from what info your given.
2.
F=m*acceleration
Force cause by friction > Fs=(Coef Kf)*(force from ramp, as the block has mg on ramp, ramp pushes back ( paired forces).)
components of mg will help as well
From a FBD/sketch of the block we find N (force on block from ramp) to be mg*cos(25).
The Fs will act against the acceleration, ie jump out a plane the air resistance (Fs) wil push you up, opposite from gravity. So the Fs will act up the slope. Acting down the slope we have F=ma, the block moving at 3.6ms^-2, and we know the mass.
Forces(net): So going down the slope we have component of the weight mgsin25 and up (Coef Kf)*N. The block is moving down the slope so. ma=mgsin25-(Coef Kf)*N
b)
the force down the slope is ma=mgsin25-(Coed Kf)*N (as the friction is pulling up the slope) from components earlier.
now the acceleration down the slope, (cancelling m over eq)
a=gsin25- (Coef Kf)*N
Note: As it is presumably the same block with more mass, same surface, Coeffecient is the contact between the two surfaces, surfaces didn't change so remains the same. I always found myself if the mass changed wanting to change the coefficient.
Ok so the force of gravity = (75 kg)(9.81m/s)= 735N
The Normal force = (735)(Cos25)= 666N
The force down the ramp= (75kg)(9.81)(Sin25)= 311N
Fnet= ?
How do I find the force of friction so that I can figure out the net force?
Think I got it.
Fx= max
=(75)(3.6)=270
311-270=41
41/666= .061 = Coeff. friction
That agrees with the answer in the book
thank you for helping me out.
I posted a thread with this exact problem five minutes ago, seems like we were both having the same issues on the same problem in the same book.
weird, huh?
thank you so much for helping me.
i think i got it now. i was confused about the sine and cosine stuff. thanks for the helps!-Fin
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
