Oxidation of Aldehyde with Potassium Dichromate(VI)
  • Thread starter Thread starter DK168
    Oxidation
The discussion centers on the oxidation of aldehydes using potassium dichromate(VI) in an acidified solution. Participants explore the suitability of different acids for acidification, the chemical mechanisms involved, and the effectiveness of various conditions for the oxidation process.
  • One participant suggests that potassium dichromate(VI) can be used to oxidize aldehydes and questions whether sulfuric acid can be replaced with other acids.
  • Another participant proposes nitric or perchloric acid as alternatives, noting that these acids can prepare chromic acid through dehydration of chromate/dichromate.
  • A participant explains that while any strong acid can technically be used, sulfuric acid is preferred due to its relatively inert nature and the high concentration of H+ it provides, which is important for maintaining redox potential.
  • There is a discussion about the hydration of chromium compounds and the role of sulfuric acid in forming active chromate species, with references to the Jones oxidation mechanism.
  • Some participants argue against the effectiveness of phosphoric acid and bisulfate as strong acids, stating that they do not dissociate sufficiently in solution.
  • One participant raises a concern that the method described may be more suitable for qualitative testing rather than a robust oxidation method, suggesting that there are milder oxidation reactions available in organic chemistry literature.
  • Another participant discusses the equilibrium of dichromate ions in solution and how adding acid can shift this equilibrium to favor dichromate formation.
Participants express differing views on the suitability of various acids for the oxidation process, with no consensus reached on the best choice. There is also disagreement regarding the effectiveness of the described method as a reliable oxidation technique.
Participants highlight the importance of acid strength and dissociation in the oxidation process, noting that the effectiveness of alternative acids may depend on their chemical behavior in the reaction environment.
This discussion may be of interest to chemistry students, researchers in organic chemistry, and practitioners looking for insights into oxidation reactions involving aldehydes and the role of acids in such processes.
DK168
One method to oxidize aldehyde is by using acidified potassium dichromate(VI) solution
The step: A small amount of potassium dichromate(VI) solution is acidified with dilute sulphuric acid and a few drops of the aldehyde is added. If nothing happens in the cold, the mixture is warmed gently for a couple of minutes - for example, in a beaker of hot water. The presence of aldehyde will turn the orange solution into green solution.
Question. Is sulphuric acid can be replaced with other acid to acidified the solution? Thanks in advance :)
Chemistry news on Phys.org
DK168 said:
other acid
Nitric? Perchloric? You are preparing chromic acid (the oxidizer) with a dehydration of chromate/dichromate.
Yes, but no.
The reduction half reaction is
Cr2O72- + 14H+ + 6e- → 2Cr3+ + 7H2O
so it requires plenty of H+ to keep the redox potential high (think in terms of the Nernst equation). Technically any strong acid will do, but it happens that most common strong acids that can be used are themselves oxidizing. Perhaps with the exception of HCl, but chlorides can get oxidized to Cl2 - and it is not something you want to have produced in the solution, as it can make a mess of your molecule.
SO42- happens to be relatively inert and as such rarely interferes with other reactions, which makes the sulfuric acid a perfect choice whenever you need a highly acidic solution.
There is way too much water in dilute sulfuric acid to dehydrate chromate. You generally hydrate chromium (VI) oxide to get chromic acid. Or you hydrate dichromate to get dichromic acid. See link below.
DK168 said:
oxidize aldehyde
Aldehydes are generally pretty easy to oxidize (sometimes annoyingly so), so you can get away with pretty mild conditions. In fact, many aldehydes will oxidize if you leave them out in air under light for a few days. Also, Borek pointed out:
to which I'll add: 1M H2SO4 = 2N H2SO4, so you get more H+ bang for your H2SO4 buck. Phosphoric acid donates even more protons per mole, so that will probably work as well.
The acid mainly catalyzes the formation of the active chromate species and the chromate ester, which reductively disproportionates to give the carboxyl and a Cr(IV) species. The general mechanism for Jones oxidation can be found here:
http://www.organic-chemistry.org/namedreactions/jones-oxidation.shtm
No and no. HSO4- is a weak acid, so in typical case where we use sulfuric acid for acidification it is almost not dissociated at all (in 1M solution only about 1-2% dissociaties up to SO42-). This is even worse for the phosphoric acid, as H3PO4 is weaker even than HSO4-.
You're right of course. Thanks for the correction. Though I doubt it matters for the Jones oxidation: you probably don't need very much acid to push the reaction forward.
That sounds an awful lot like a qualitative test for the presence of aldehydes. It is a qualitative technique, not a real suitable method for oxidizing aldehydes. I'm sure Morrison and Boyd (or any organic text) has several milder oxidation reactions that will suffice.
Mea culpa. Went from a "general" statement regarding acid anhydrides to a specific case without thinking.
Dichromate Ions are formed when solid K2Cr2O7 is dissolved in water and the aqueous solution can be represented by an equilibrium :
Cr2O7 2- +H2O <---> CrO42- + 2H+
Now, this equilibrium is pH sensitive and if you want more dichromate ions, you can add more acid (HCl or H2SO4 or HNO3), which will follow Le Chatelier's principle and shift the equilibrium to the left.
I guess all strong acids can work as long as they are not reacting with potassium dichromate.
Thank you all for the helpful information..
15K
15K
  • · Replies 19 ·
11K
22K
9K
