Troubleshooting P-Channel MOSFET Switching in Electrical Power Systems
  • Thread starter Thread starter urb
    Mosfet
The discussion centers on troubleshooting an issue with P-channel MOSFETs in an electrical power system where all seven MOSFETs turn on simultaneously when one is activated. The circuit design includes gates connected to ground and sources linked to a microcontroller. The user suspects that the microcontroller may be sending high signals (1s) to the sources of the P-channel MOSFETs, which keeps them all turned on. There is a request for a schematic to better understand the setup and diagnose the problem. Clarification on the signals being sent from the microcontroller is crucial for resolving the issue.
urb
Hi all,
I'm using 7 P-channel mosfets to switch different loads using 1 microcontroller on an electrical power and distribution system. My circuit is as follows for each of the 7 Mosfets.
Gate: through a resistor to ground on microcontroller and through a High value (600 kilaohms)
Drain: to load
Source: I/O line from microcontroller and input power
So all the gates are interconnected to the ground on the cpu
The problem I'm having is that when I turn one mosfet on all the mosfets turn on and I can't figure out why. I am unable to use N-Channel mosfets. Any help on this matter would be very very appreciated
Are you sending 0s or 1s from microcontroller to source of PMOSs when all of them gets turned on ?
if the gate is connected to gnd, sending 0 to PMOS's source will turn it off, but sending 1 keeps it turned on all the time. I suspect that your microcontrollers are sending 1s to all the PMOSs.
I don't understand what you have from your description. Can you post a schematic?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
