Packing Fraction of Cylinders - Answers to Your Questions
  • Thread starter Thread starter marmot
    Fractions
The packing fraction of randomly jammed cylinders is determined by the ratio of their filled volume to the total volume of the container. It is influenced by the cylinders' dimensions and the number of cylinders present. The random packing fraction varies based on the shape's degrees of freedom and contact points, differing from the closest packing fraction, which represents the most efficient arrangement. While there are established models for spherical shapes, the analytical solution for cylinders remains unresolved. This discussion highlights the complexities involved in estimating packing fractions for cylindrical objects in three-dimensional space.
marmot
Hey. I have a question. What is the packing fraction of a container full of randomly jammed cylinders? Also, does the packing fraction depend on the ratio of the radius to height of the cylinder? There is some contest of finding certain amount of cylindrical objects inside a container (I can't weight it) and I know that for certain shapes, you can use the packing fraction to estimate (Spheres have a random packing of .64). I already planned the way I am doing this (finding volume, size of discs, etc) and this would be perfect with the packing fraction of cylinders. Youll help me loads.
Thanks
Isn't the packing fraction just the filled volume divided by total volume?
So it would depend on the radius and height of the cylinders, and how many of them there are. If you have N cylinders of radius r and height h in a container of volume V then the packing fraction is
\eta = N \pi r^2 h / V.
[edit]Ah, sloppy reading from my part. I guess your actual question is: if we throw in with randomly oriented cylinders until no more can be fitted in the volume, what is the expectation value of N?[/edit]
Exactly. The random packing fraction of a shape depends greately on its degrees of freedom and "contact point". It is used a lot in thermodynamics but you can use it to find the number of randomly packed things in a container too. It is different from "closest" packing fraction, which would be the most efficient way to pack a certain shape.
Here is a paper on jammed MandMs:
http://www.cims.nyu.edu/~donev/Packing/JammedMM.pdf
I'm not sure the case for cylinders hase been solved. And I'm not sure any geometry other than monodisperse spherical (Percus-Yevick model, IIRC) has an analytical solution.
Edit- I should point out that I am referring to 3D...
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
