Parallel plate capacitor problem
The discussion centers on the behavior of a parallel plate capacitor when connected to a battery and subsequently disconnected. Key conclusions include that increasing the area A after disconnection increases the stored energy U (A), while increasing the plate separation d also increases U (B). The capacitance C increases with area A when connected to the battery (E), and decreasing the plate separation d increases capacitance C after disconnection (C). However, increasing d decreases the voltage V after disconnection (F) and does not affect V when connected (D).
  • Understanding of parallel plate capacitor equations, specifically C=(epsilon_0)A/d
  • Knowledge of electric field concepts and their relation to voltage and charge density
  • Familiarity with energy stored in capacitors, U=(1/2)(epsilon_0)(E_field)^2*A*d
  • Basic principles of charge conservation in capacitors
  • Study the effects of varying plate separation on capacitance in parallel plate capacitors
  • Explore the relationship between charge density and voltage in capacitors
  • Learn about energy storage in capacitors and its dependence on physical parameters
  • Investigate the implications of connecting and disconnecting capacitors from power sources
Students and professionals in electrical engineering, physics enthusiasts, and anyone studying capacitor behavior in circuits.
smithnh
[SOLVED] Capacitor problem
Problem:
A parallel plate capacitor with adjustible plate separation d and adjustible area A is connected to a battery. The capacitor is fully charged to Q Coulombs and a voltage of V Volts. (C is the capacitance and U is the stored energy.) Give all correct answers concerning a parallel-plate capacitor charged by a battery (e.g. B, AC, CDF).
A) After being disconnected from the battery, increasing the area A will increase U.
B) After being disconnected from the battery, increasing d increases U.
C) After being disconnected from the battery, decreasing d increases C.
D) After being disconnected from the battery, increasing the area A will increase V.
E) With the capacitor connected to the battery, increasing the area A will increase C.
F) After being disconnected from the battery, increasing d decreases V.
Relevant equations:
(1) C=(epsilon_0)A/d
(2) V=E*d=(sigma_0)*d/(epsilon_0)
(3) U=(1/2)(epsilon_0)(E_field)^2*A*d
3. The Attempt at a Solution
A) seems to be true because of Eq (3)
B) seems to be true because of Eq (3)
C) seems to be true because of Eq (1)
D) seems to be false because the potential does not depend on the area in Eq (2). However, I also considered that the if the charge stays the same it will decrease the charge density, sigma_0 for increasing area and thus it will decrease V but this also supports the answer being false.
E) seems to be true because of Eq (1)
F) seems to be false because increasing d will increase V by Eq (2)
Answers already tried:
AB
ABE
ABCE
ABCDE
I cannot seem to figure this one out despite the fact that it seems so simple, where am I going wrong
What I needed to think about was the fact that the battery cannot suplicate more charge thus Q is constant. After realizing that sigma_0 is defined as Q/A that then brought to question how I was thinking about the electric ield and was able to figure the answer.
  • · Replies 18 ·
  • · Replies 20 ·
