Parallel plate capacitor (voltage and charge relative to distance)
In a parallel plate capacitor without a battery, moving the plates farther apart increases the potential (V) due to the work done against the electric field. The relationship between voltage and distance is influenced by the electric field (E), which remains approximately constant as long as the separation distance is small relative to the plate dimensions. The confusion arises from misapplying the inverse square law, which is not applicable in this context. As the distance increases beyond a certain point, the electric field does decrease, but within practical limits, it remains relatively stable. Understanding this distinction clarifies why potential increases with distance in a parallel plate capacitor.
swarm
Hi all.
I'm struggling to understand something about PP capacitors. Let's say there is no battery connected to a PP capacitor.
Why does the potential (V) INCREASE when the plates are moved farther apart?
- we know that: dv = -Ed (in a constant E)
however as d increases, E decreases with the inverse square of d, falling off exponetially while d falls of linearly, so since E is getting smaller faster than d is getting larger, souldn't dv decrease as d increases?
- From a non-math perspective I understand it, work must be done to pull the plates apart, thus potential energy is increased, so dv would increase. My math just doesn't agree though.
Can someone point out my error? Many thanks in advance, this has been driving me nuts for a couple days now!
As long as the separation distance remains small with respect to the dimensions of the plates, the electric field remains constant. It does not drop off exponentially or as an inverse square with distance (as would happen with a point charge).
Thanks Doc Al, I think my problem was that I was using unrealistically high values for 'd' (1 meter or more), it makes sense now.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
