Understanding the Behavior of a Parallel Plate Capacitor: True or False?
The discussion focuses on the behavior of a parallel plate capacitor, specifically examining the effects of closing a switch to connect it to a battery. Key points include the force between the plates being proportional to the square of the charge and inversely proportional to the square of the distance when the switch is open. When the switch is closed, the charge on the plates changes, and the electric field at one plate is influenced by the potential difference and the distance between the plates. Participants emphasize the importance of using the correct equations for parallel plates rather than point charges. Clarifications on the behavior of charges and electric fields in different scenarios are encouraged for better understanding.
Physics197
The diagram shows a parallel plate capacitor with plate area A and spacing d. The capacitor can be connected to a battery of potential difference V by closing the switch. Assume d² << A.
1. The force on plate 1 due to plate 2 is F = Q²/(4πε0d²) î, where Q is the charge on plate
2.If the switch is closed and d is varied, the charge on the plates varies.
3. If the capacitor is initially uncharged and then the switch is closed, a charge −Q = ε0AV/d appears on plate 1.
4. The force between the plates varies as 1/d if the switch is open.
5. If the switch is closed, the electric field at plate 1, due to plate 2, is V/(2d) î
Select true or false.
1. True - from coulombs law (charges will be the same on either plate)
2. i think false, can the charges be changed..
3. true (unless if that plate should be positivly charged)
4. false - coulombs law
5. false, could be true, but can't find an equation that tells me that
http://f.imagehost.org/view/0778/plates
anyone..
Physics197 said:
anyone..
You'll probably get better responses if you include all relevant equations in your attempt at a solution. For example, you mentioned "coulomb's law" in a couple of your attempted answers. But Coulomb's law, as it is generally written, applies to point charges. What is the corresponding equation for parallel plates? Things like that might help. Sometimes, explanations may be in order -- for example, which things in a given equation are held constant when the switch is open, and which things are held constant when the switch is closed.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
