Parametrics Word Problems: Solving for Height and Distance of a Ball in Motion
  • Thread starter alexneco
In summary: For calculating the height after 3 seconds, I plugged in the parametric x=(90cos60)t, y=5+(90sin60)t-16t^2 and evaluated for x=3 on the graph, which gave me y= 4.02ft. In addition, when I try to evaluate the horizontal distance by plugging in t=3 I get -257.15.
alexneco
Find the height of the ball after 3 seconds if the ball is hit with an initial velocity of 90ft per second at an angle of 60° from an initial height of 5 ft.
Find the horizontal distance a ball travels after 3 seconds if the ball is hit with an initial velocity of 90 ft per second at an initial height of 5 ft.
If a ball is hit with an initial velocity of 110 ft per second at an angle of 45° from an initial height of 2 ft, how far will the ball travel before it hits the ground? How long will it be in the air?
x=(v0cos θ)t and y=h + (v0 sin θ)t-16t^2
I have tried plugging in the numbers to the equations but they do not work.
x=(90cos60)t y=5+(90sin60)t-16t^2
x=(110cos45)t y=2+(110sin45)t-16t^2
As far as I can make out you do have the correct formulas, so what, exactly does not work out? Show us the complete numbers. (The only thing that comes to mind is that you *might* be evaluating sin and cos using software that expects angles in radians, while you are using degrees.)
I don't know how exactly to find horizontal distance but these are the numbers i came up with after entering the equation in the calculator
after 3 seconds: 4.02ft
How long the ball will be in the air: 339.273 seconds
How far it traveled before hitting the ground: y=2+(110sin45)339.273-16(339.273)^2= -1809940.95
You should write x=(90cos60)t, y=5+(90sin60)t-16t^2; these are two *separate* formulas.
The horizontal distance is just x, so substitute t = 3 into the expression and evaluate.
When you say "after 3 seconds: 4.02ft", exactly what are you calculating? Horizontal distance? Vertical height, or what? Anyway, I cannot get anything like 4.02 ft; I get much larger numbers.
Please show the details of your work. Do not just tell us what your calculator shows; tell us your values of 90*cos(60) and 90*sin(60), etc. Without knowing what you are doing we have no way to help you overcome your problems!
90cos60 = -85.71, 90sin60 = -27.43
x= -85.71(3), y= 5+(-27.43)3-16(3)^2
x= -257.13, y= -221.29
Should I be solving the equation in degrees instead of radians?
Your calculations are wrong because you are evaluating sin and cos in radians instead of degrees.
cos 60 degrees = 0.5
sin 60 degrees = 0.866
You should at least know the sin and cos of 0, 30, 45, and 60, and 90 degrees by heart.
It is mindless errors like these which cause you to spend extra time on your homework and could cause you to fail an exam.
x= (90cos60)t, y= 5+(90sin60)t-16t^2
x= 90(.5)t, y= 5+(90(.866))t-16t^2
For horizontal distance t=3 so,
x= 90(.5)3 → x= 135ft
For the height of the ball after 3 seconds,
y= 5+(77.94)3-16(3)^2 → y= 94.82ft
2.
x= (110cos45)t, y= 2+(110sin45)t-16t^2
To find how long the ball would be in the air I plugged the parametric equation
x= (110(.707))t, y= 5+(110(.707))t-16t^2 into the calculator and evaluated the table for t which gave me 4.92 seconds.
To find the distance of how far the ball traveled, I used the same equation above and looked at the parametric where y=0 which gave me 383.064 ft.
If you had paid any attention at all to what I told you before, you would have realized this error right away; it was something I mentioned in my very first response to you.
Related to Parametrics Word Problems: Solving for Height and Distance of a Ball in Motion
1. What are parametrics word problems?
Parametrics word problems are mathematical questions that involve using a set of equations to describe the relationship between two or more variables. These problems often involve finding the values of these variables that satisfy the given conditions.
2. How do I solve parametrics word problems?
To solve a parametrics word problem, you must first identify the given equations and variables. Then, you can use algebraic techniques such as substitution or elimination to find the values of the variables that satisfy all the equations. It is also important to double-check your answers and make sure they make sense in the context of the problem.
3. What are some common applications of parametrics word problems?
Parametrics word problems are commonly used in physics, engineering, and other scientific fields to model real-world situations. They can also be used in economics and finance to analyze relationships between different variables.
4. Are there any tips for solving parametrics word problems?
One tip for solving parametrics word problems is to carefully read and understand the given information before attempting to solve the problem. It can also be helpful to draw diagrams or create tables to visualize the problem and organize your thoughts. Another tip is to practice solving similar problems to become more familiar with the process.
5. What are some common mistakes to avoid when solving parametrics word problems?
One common mistake when solving parametrics word problems is to mix up the given equations or variables. It is important to clearly define and label each equation and variable to avoid confusion. Another mistake is to forget to check your answers and ensure they make sense in the context of the problem. It is also important to pay attention to units and make sure they are consistent throughout the problem.
  • Precalculus Mathematics Homework Help
  • General Math
  • General Math
  • General Math
