Finding Centroid and Second Moment of Area for Complex Sections
  • Thread starter Thread starter Chantry09
    Axis Theorem
The discussion focuses on determining the centroid and the second moment of area for a complex shape. The user has calculated Y(bar) as 40 mm but is struggling to find the centroid's position, which should be 862,000 mm. There is confusion regarding the definition of the centroid as the geometric center, especially given the symmetry of the figure. The user is seeking clarification on the calculations and the correct application of relevant equations. Overall, the thread highlights the challenges faced in understanding centroid calculations for complex sections.
Chantry09
Im having a hard time getting my head around this, any help would be much appreciated.
Determine the position of the centroid and calculate the second moment of area about a horizontal axis passing through the centroid for the following sections shown. Attached is the image of the shape, including dimensions.
A x Y(bar) = (A1 x Y1) + (A2 x Y2)
IX = Ix + Ah(squared) [Not sure if this equation is correct]
I know Y(bar) to equal 40mm for the attached shape. However i don't know how to get from the y(bar) to the position of the centriod. The answer should be 862000.0mm, i just don't know how to get there, everything i try comes up with a different result.
Well, you have me confused! (Not all that difficult.) In most textbooks, "Y(bar)" (\overline{Y}[/tex]) <b>means</b> the y-component of centroid. I, frankly, don&#039;t see how you could have gotten 40 mm. That&#039;s only a little bit above the bottom line. You do understand, don&#039;t you, that the &quot;centroid&quot; of a figure is the geometric center? If this, very symmetric, figure goes from 20 mm at the bottom to 120 mm at the top, 10mm on the left to 80 on the right, where do you think center is?
Yeah [PLAIN]https://www.physicsforums.com/latex_images/16/1615993-0.png is what i meant, i couldn't find the symbol. My diagram might not be clear, but the height is 80mm and considering its symetric in the x and y direction i thought [PLAIN]https://www.physicsforums.com/latex_images/16/1615993-0.png = 1/2 total height?
Is that not right?
Bump. On my hands and knees here guys :S
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
