Partial Derivative: Finding the vector on a scalar field at point (3,5)
fluxer5
A scalar field is given by the function: ∅ = 3x2y + 4y2
a) Find del ∅ at the point (3,5)
b) Find the component of del ∅ that makes a -60o angle with the axis at the point (3,5)
del ∅ = d∅/dx + d∅/dy
I completed part a:
del ∅ = (6xy+4y2)\hat{i} + (3x2+8y)\hat{j} = 120\hat{i} + 67\hat{j} (this answer is correct)
I am having trouble with part b. My gut feeling is that I need to take a dot product; project the vector from 'part a' onto the vector that makes "a -60o angle with the axis."
Assuming the equation is |a||b|cosθ,
  • I think a = 120\hat{i} + 67\hat{j}
  • I'm not sure what b is. Maybe a unit vector?
  • I'm thinking θ is 60o + atan(67/120)
Also, I'm assuming the "axis" that the problem refers to is the x-axis. The answer is -13.02.
Thank you for any help.
EDIT: Oops. 120i + 67j is not correct; it's 90i + 67j. |90i + 67j|cos(60+atan(67/90)) = -13.02
I completed part a:
Hello luxer5. Welcome to PF !
\cos(\theta)\hat{i}+\sin(\theta)\hat{j} is a vector that makes an angle of θ with the positive x-axis. It also happens to have a magnitude of 1 .
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
