Partial Differentiation -- y deleted or ignored?
Prof. 27
Given: z = f(x,y) = x^2-y^2
To take the partial derivative of f with respect to x hold y constant then take the derivative of x.
∂f/∂x = 2x
What I don't understand is why such would equal 2x, when the y is still there it just isn't variable and is ignored. Wouldn't it be:
2x - y^2
where y is a constant squared?
In another example this kind of thing occurred:
z = f(x,y) = x^3*y
∂f/∂x = 3x^2*y
where y is a constant unknown.
So why the different pertaining to y in these two answers?
Thanks so much, Bertrand Russell
None really.
http://en.wikipedia.org/wiki/Partial_derivative
http://www.centerofmath.org/mc_pdf/sec2_1.pdf [/B]
∂f/∂x = 2x
2x - y^2
z = f(x,y) = x^3*y
∂f/∂x = 3x^2*y
None really.
We take the partial derivative of the entire function..So for f(x,y)=x2-y2, the derivative of x^2 is 2x but the derivative of y^2 w.r.t.x must be 0 since it is constant..Same goes for 3x^2*y..
Likes Prof. 27
Got it. Thanks so much.
∂f/∂x = 2x
2x - y^2
z = f(x,y) = x^3*y
∂f/∂x = 3x^2*y
None really.
First, in both cases y is treated as a constant. For example:
##\frac{d}{dx}(x^2 + a^2) = 2x##
And
##\frac{d}{dx}(x^3a) = 3xa##
On your main point: a partial derivative (wrt x) is the gradient of the curve you get when you hold y constant. You could think of taking y = 0, 1, 2... and see what curves you get. Whatever value of y you choose, you get a parabola ##z = x^2 + n^2## where ##n## is whatever value of y you are considering. This curve has the usual derivative and does not get steeper as y increases: it's the same shape for any value of y.
Whether y appears in the partial derivative depends on whether the value of y affects the derivative. For ##z = x^2 + y^2## it doesn't: the partial derivative is independent of y. But for ##z = x^3y## the partial derivative wrt x does depend on y.
It's exactly the same as whether a constant ##a## affects the ordinary derivative of a function of x.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
