Partial fraction decomposition for .
The discussion focuses on the partial fraction decomposition of the expression (3x-1) / (x(x^2 + 4)). Participants clarify the correct form of the decomposition, which is A/x + (Bx + C)/(x^2 + 4). After multiplying through by the denominator, they derive coefficients A, B, and C, ultimately finding A = -1/4, B = 1/4, and C = 3. There is some confusion regarding the notation and the importance of using parentheses for clarity. The final consensus is that the derived values for A, B, and C are correct, leading to the accurate decomposition.
itachi8
Partial fraction decomposition for...
1. 3x-1 / x(x^2 +4)
3. A/x + Bx + C/ x^2 +4
after multiplying through by the denominator and my attempt at finding A,B,C i get this:
3x-1/x(x^2+4) = - one fourth / x + one fourth + 3/ x^2 +4. I don't feel comfortable about this answer.
The answer i get is:
-(1/4)ln(x)-(1/8)ln(x^2+4)+(3/2)arctan(x/4)+c
i think you made a mistake at Bx which is supp0sed to be B(2x)/(x^2+4).
@itachi: Please either learn LaTeX or use parentheses. I originally read this:
itachi8 said:
1. 3x-1 / x(x^2 +4)
as this:
3x - \frac{1}{x(x^2 + 4)}
Then I originally read this:
as this:
\frac{A}{x} + Bx + \frac{C}{x^2 + 4}
And finally your answer:
I thought was this:
-\frac{1/4}{x} + \frac{1}{4} + \frac{3}{x^2} + 4
But it looks like you meant this as your answer:
-\frac{1/4}{x} + \frac{\frac{1}{4} + 3}{x^2 + 4}
If so, you forgot an x next to the 1/4 in the 2nd fraction.
@median27, I'm not sure how you got your answer.
Disregard my post. I apply integration. I thought your query about partial fractions was under integral calculus. I've never encounter partial fraction decomposition in other subjects other than in integral so i assumed it as a query about integration. :D
itachi8 said:
1. 3x-1 / x(x^2 +4)
(3x-1)/(x(x^2 +4))
A/x + (Bx + C)/(x^2 +4)
Parentheses are important !
Show the rest of your work (with correct grouping) so we can see what you've done.
sorry about the mistake i made with the problem. yes the problem is (3x-1)/(x(x^2 +4)). From the equation i came up with A/x + Bx + C/ x^2 +4. After multiplying through the equation by the denominator (x(x^2+4)) i get A(x^2 +4) + (Bx +C)(x). That gives me Ax^2 + 4A + Bx^2 + Cx. After equating coefficients i come up with A + B=0, C=3, and 4A=-1. I solve for 4A which gives me A= -1/4 and plug this into A + B=0 which gives me B= 1/4. This leads me to my answer which is (- one fourth / x) + (one fourth x + 3/ x^2 +4). Is this correct?
Don't mean to be so picky, but you're still not applying enough parentheses. This looks like
\frac{A}{x} + Bx + \frac{C}{x^2} + 4.
Without LaTeX, you should have typed
And your answer looks like
-\frac{1/4}{x} + \frac{1}{4}x + \frac{3}{x^2} + 4
But yes, I am getting the same values for A, B, and C.
EDIT: Wow, 500 posts already?
Is A/x + Bx + C/x^2+4 supposed to be A/x + Bx + 4 + C/x^2, or is it A/x + Bx + C/(x^2+4)? You don't need to use LaTeX (although it would be better if you did), but you should use brackets. Why wouldn't you? It is easy and avoids confustion.
RGV
