Why is the angle adjacent to the horizontal 30°?
In summary, the book provides the answer with the working, which is:F+10cos30°=98sin30°F=98sin30°-10cos30°=40.3N
King
43
The question is, "A particle of mass 10kg is at rest on a rough plane inclined at 30° to the horizontal. A horizontal force of magnitude 10N acts on the particle. a) Find the magnitude of the friction force on the particle."
URL TO IMAGE (I added the green to help you understand why I am confused): i209.photobucket.com/albums/bb180/newguyjb/forcesdiagram.jpg
The book provides the answer with the working, which is:
F+10cos30°=98sin30°
F=98sin30°-10cos30°
=40.3N
However, I don't understand how they have decided that it is 10cos30°. On the diagram I provided (which is the link) in green the area which is not in the diagram in the book, but which relates to why I am confused as to why it is 10cos30°. Could someone explain why it is 10cos30°.
Thanks for any help.
Hi King,
That equation is the components along the incline of all the forces. What is the angle between the 10N force and the incline? The component of the 10N force that you want in that equation would be the side adjacent to that angle.
Hrm... I get a different answer too. I may be making an error myself, but here's how I do it:
If you rotate it so that the surface is flat and below the particle, you can define a new "horizontal" that has forces to the right that are a component of the applied horizontal force and gravity. The magnitude of our friction is now acting completely to the right in this frame (positive x in the new system).
The total force in this new "horizontal" frame is zero and the applied force (10 N) pulls off at an angle of 30 degrees downwards and to the right and gravity pulls downward and to the left at and angle of 60 degrees from the new "horizontal".
The normal force can be ignored since it acts "vertically" in our new system and our friction force acts "horizontally" in our new system.
So you have:
(firction + applied force both acting "right") = (gravity acting "left")
F+10Ncos30=98Ncos(60)
F = [98cos(60)-10cos(30)]N = 47.5N
So I get the same 10Ncos30 term they do, but my gravity term is off :/
You have your force diagram wrong;
or whilst that's waiting to get validated
stopouts.com/pic1.jpeg
Since frictional forces act parallel to the plane and the object's at rest, the force pulling it down the plane must be equal to the frictional force keeping it in place + the component of the 10N force acting parallel to the plane.
Hi Pythagorean,
Your formula looks correct. cos(60)=sin(30)
I think you might have made a numerical error; I'm not getting 47.5 from your expression.
alphysicist said:
Hi Pythagorean,
ah, of course:
cos(60) = sin(60+90) = sin(150) = sin(30)
I was thrown off because our end calculations still don't match.
Hi all,
Thank you for all the replies :)
I understand how to resolve forces, and from the question I understand that it is F+?-98sin30°, just the ? part confuses me. If you take the slope it is 180°, the forces (one going right and the other going down) are 90°, thus 90° remains as the sum of the missing angles to create 180°. Also, one can calculate that the right-angled triangle on the left has 90°+30°=120° and so 60° remains. Thus, if we go back to where the 10N force is, the angle adjacent to the horizontal must be 30°. And oh my God I just solved my own question. lol!
Thanks for everyone's help.
What is particle force?
Particle force is a type of force that acts on individual particles, such as atoms or subatomic particles, within a system.
What are the four fundamental forces of particle physics?
The four fundamental forces of particle physics are gravity, electromagnetism, strong nuclear force, and weak nuclear force.
How do particle forces affect the behavior of matter?
Particle forces play a crucial role in determining the structure, properties, and interactions of matter at a microscopic level. They can cause particles to attract or repel each other, resulting in the formation of larger structures and the behavior of materials.
What is the relationship between particle forces and energy?
Particle forces are closely related to energy, as they are responsible for the transfer and transformation of energy within a system. For example, electromagnetic forces are involved in the conversion of electrical energy into light or heat.
Can particle forces be manipulated or controlled?
Yes, particle forces can be manipulated or controlled through various means, such as changing the distance between particles, altering their charges, or applying external forces. This manipulation is the basis for many technological advancements, such as nanotechnology and particle accelerators.
