Particle in 3D Box: Table of Energies & Degeneracies
  • Thread starter Thread starter siifuthun
    3d Box Particle
For a particle in a 3D box with dimensions a, b, and c (where a ≠ b and b = c), the quantum numbers n_x, n_y, and n_z should range from 1 to 4, as n cannot be zero. This results in 40 distinct energy states due to the degeneracy of certain combinations, specifically with n_y and n_z being interchangeable. The energies can be expressed as multiples based on the ratio of a^2 to b^2, which is given as 2, but numerical values cannot be derived directly. The discussion clarifies the confusion around the number of states and emphasizes the importance of correctly counting non-degenerate combinations. Understanding these principles allows for a more concise approach to listing the energy levels and their degeneracies.
siifuthun
This is the question:
For a particle in a three-dimensional box of sides a, b, and c, where a does not equal b and b=c, make a table of n_x, n_y, and n_z, the energies, and the degeneracies of the levels in which the quantum numbers range from 0 to 4 (Take ((a^2)/(b^2)) = 2).
Ok, I think I have an idea of what I'm supposed to do, but I'm a little confused on two parts of the question. When they ask for a table using quantum numbers from 0 to 4, would that mean I'd have to make a long list with n_x, n_y, and n_z like:
0 0 0
0 0 1
0 0 2
0 0 3
0 0 4
0 0 5
and so on until I've listed all 125? Someone in my class said that there were 64 because of the zeroes, however I didn't really understand why we would be able to. I know that:
http://img165.imageshack.us/img165/1706/01mk3.jpg
So once I list all the states, I would have to substitute in the values for n_x, n_y, and n_z - but am I supposed to be able to get numerical values for the energies? I can get solve for a in terms of b and such, then plug in, but I still wouldn't get any numbers. Once I can figure out what I have to list, all I'd have to do to list the degeneracy is count the amount of states with different quantum numbers that have the same energy.
I assume they mean n_x=1,2,3,4 n_y=1,2,3,4 n_z=1,2,3,4
Since b=c you get 40 different cases, not 64, because for instance n_y=2,n_z=1 and n_y=1,n_z=2 are energy equivalent cases. You can combine n_y,n_z in 10 different non degenerate ways(not 16) and then combine that with the 4 possible cases for n_x
n can not be zero that's probably what your friend mean. Consider a particle in a one dimensional box. If you put n=0 it basicly means there is no particle. the lowest state is when all three n values are =1.
Numerical answeres doesn't seem to be possible but you can easily express them as multiples since \frac{a^2}{b^2}=2
Hope this helped a bit?
I see what you mean now, although now I feel bad since I went ahead and listed 64 cases. At least now I can shorten my answer. Thanks a lot, this cleared up the bit about the zero.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
