I'm looking at Jackson v3 eqns. 14.26-14.28 (hopefully you have a copy), they derive the formula as in the PDF as being dependent on the acceleration, then write acceleration as dp/dt, then write dp/dt as dE/dx, which they interpret as being entirely from the external field. In other words, the acceleration of the particle is entirely caused by the external fields.
So does it depend on the particle energy? No, only on the particle's acceleration.
Does it depend on gamma? No, it depends on dE/dx. BUT, if you try to write dE/dx in terms of dbeta/dt, then the factor of gamma^6 reappears. This is irrelevant in your problem (as in real experiments), as you have dE/dx given.
So I agree with you that the Larmor formula will give you the right answer. But, as presented in Griffiths for example, it only applies to non-relativistic motion -- if you want to use it for relativitistic particles, you have to explain why it is valid.
As for circular motion, this is correct in terms of the particle acceleration -- if you write it in terms of dE/dx = dp/dt (Jackson 14.47), it will depend only on external parameters as before -- except for the factor of gamma^2, which cannot be gotten rid of. This is why we can't do e-e+ collisions in the LHC for example ("synchrotron radiation"); we need an ILC.
