Find Special PCB Designing Tips and Tricks Online
PCB design tools come with manuals, but many valuable tips are gained through experience. Online resources, such as Google searches for PCB design tutorials, can provide insights and tricks that enhance design skills. Many designers share their expertise on forums and blogs, offering practical advice beyond standard manuals. Engaging with these resources can significantly improve PCB design proficiency. Exploring these online platforms is essential for both novice and experienced designers.
parsafarmh
Hi,
As you know , PCB design tools have manuals accompanying them ,but there are points in designing that a PCB designer earns by long time experiment.Now,are there any places on the web telling us these special points or tricks?
google PCB Design Tutorial, and you will get many hits. Have fun!
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
