PDE - Need help getting started.
  • Thread starter Thread starter walter9459
    Pde
walter9459
Derive the differential equation governing the longitudinal vibration of a thin cone which has uniform density p, show that it is
1/x/SUP] d/dx(x du/dx) = (1/c) d u/dt
Hint: The tensile force sigma = E du/dx where E is the Young's modulus (a constant), u is the longitudinal displacement and x is the longitudinal coordinate.
I wasn't sure where to start so if someone give help me understand how to start this problem I would appreciate it.
Write F = ma [/tex] for a longitudinal element of the rod of length dx. The force on the left is the tensile stress times the area, i.e.,<br /> &lt;br /&gt; E A(x) du/dx&lt;br /&gt; <br /> pointing to the left. <br /> Can you do the rest?
Okay now I have the following:
F = ma
F = EA(x)U(x)
= d/dx[EA(x)d/dx)] = m(x) d^2u/dt^2
u(x,t) = U(x)T(t)
d/dx[EA(x) d/dx[U(x)T(t)]] = d^2/dt^2 [m(x)T(t)]
t(t) d/dx [EA(x) d/dx [U(x)T(t)] = 1/T(t) d^2/dt^2 T(t) = -w^2
d/dx[EA(x) d/dx U(x)] + w^2m(x)U(x) = 0
I need to get to
1/x^2 d/dx[x^2 U(x)] = 1/c^2 U(tt)
but not sure if I'm on the right path and how I get from my result to the required result.
Regards,
Margaret
OK, don't introduce the separation of variables form u(x, t) = T(t) U(x). At this stage we are merely trying to derive the PDE, not solve it.
The force on the left face of the differential element is
<br /> F(x) = EA(x)\frac{\partial u}{\partial x}<br />
The force on the right face will be (using a Taylor series)
<br /> F(x + dx) = F(x) + \frac{\partial F}{\partial x}dx
pointing to the right.
Hence the net force is: (you write it down).
Next, the mass of the element is m = \rho A(x) dx, where \rho is the density.
The acceleration of the element is \partial^2 u/\partial t^2.
So F = ma becomes (you write it down).
Next introduce c^2 = E/\rho into the above equation. This gives (you write it down).
Next write A(x) = \pi R^2(x), where for a cone R(x) = \alpha x, \alpha being the slope of the cone and x is measured from the tip of the cone. Introduce this into the equation. This gives the answer. Done?
Thank you for your patience and help in explaining this in a manner that I was able to understand.
hey how do u get the net force in the above question?
I know t is the FR-FL. But what would it be?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
