Pellet colliding with hanging mass example. Having trouble finding height.
A 1-kg pellet collides with a 39-kg hanging mass in a completely inelastic collision, resulting in the pellet becoming lodged in the mass. The final velocity after the collision is calculated to be 7 m/s, with a final kinetic energy of 980 joules. To determine the maximum height reached by the combined mass after the collision, the conservation of mechanical energy principle can be applied. The initial kinetic energy of the system is converted into gravitational potential energy at the maximum height. The relevant equation for maximum height can be derived from setting the kinetic energy equal to the potential energy at height h.
folsomfighter
A 1-kg pellet travels with velocity 280 m/s to the right when it collides with a 39-kg hanging mass which is initially at rest. After the collision, the pellet remains lodged in the hanging mass, i.e., it is a completely inelastic collision. The hanging mass (+pellet) then swings upward and reaches a maximum height hmax before swinging downward again. Assume that no external forces are present and therefore the momentum of the system is conserved. Solve for final velocity, final kinetic energy, and maximum height in centimeters.
Thus far, I've figured out the final velocity using the formula p(initial)=p(final), where p=mv. I've also solved for the final velocity using k(final)=.5*m*v^2.
v(final)=7 m/s
k(final)=980j
But I'm stumped on what equation to use to solve for the max height.
Thus far, I've figured out the final velocity using the formula p(initial)=p(final), where p=mv. I've also solved for the final [STRIKE]velocity[/STRIKE] kinetic energy using k(final)=.5*m*v^2.
v(final)=7 m/s
k(final)=980j
Hello folsomfighter. Welcome to PF !
If the collision occurs at time, t=0, then for any time, t>0, conservation of (mechanical) energy is in effect.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
