Pendulum mass and Newton's second law
Changing the mass of a pendulum's bob does not affect its period, as the period is determined by the length of the string and gravitational acceleration, not mass. Newton's second law indicates that while greater mass results in slower acceleration, this does not influence the pendulum's oscillation period. The formula for the period of a pendulum shows that it is independent of mass, similar to a mass-spring system where mass affects the period only when the spring constant changes. To alter the period, one must change the length of the string or the gravitational field. Thus, the initial assumption about mass not affecting the period is correct.
moomoocow
hello:)
i have a question:
if i changed the mass of the ball on the pendulum, i assume that Changing the mass of the ball would not change the period of the pendulum because gravity pulls objects towards Earth at the same speed regardless of their mass.
however
Newton's second law says that the more mass, the slower the acceleration:
which means that changing the mass of the ball on the pendulum will change the period of the pendulum.
please tell me which explanation is correct:
The first. :smile:
The period of oscillation of a frictionless pendulum for small oscillation about the equilibrium is
T=2\pi \sqrt{\frac{l}{g}}
where l is the length of the string and g the gravitationnal acceleration.In an analogy to the mass-spring system, g is the analogue of the spring constant k and l is the analogue of the mass m, because the period of oscilattion of the mass-spring system is
T=2\pi \sqrt{\frac{m}{k}}
So if you wanted to affect the period of oscillation of a pendulum in the same way as changing the mass of a mass-spring system affects the period of oscillation, you'd have to change the length of the string by the same amount as you change the mass.
thank you..
so to change the period of the pendulum, we would have to change the length of the string
yes, or move to a different gravitational field :smile:
Newton's second law: F= ma, says that for a fixed force the greater the mass, the slower the acceleration.
However, Newton's law of gravity: F= -\frac{GmM}{r^2} says that the greater the mass the greater the gravitational force.
Putting those together
-\frac{GmM}{r^2}= ma[/itex]<br /> the &quot;m&quot;s cancel so <br /> a= -\frac{GM}{r^2}<br /> independent of the mass of the object.
Which can happen (slightly) if you move from sea level to a high mountain.
Most grandfather clocks (I have one) have a screw for moving the weight up or down the pendulum bar, thus controlling the speed of the clock.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
