Pendulum Velocity Homework: Find Mass's Speed at Bottom of Path
  • Thread starter Thread starter Yae Miteo
    Pendulum Velocity
The problem involves a pendulum where a mass is released from a horizontal position, and the goal is to determine its speed at the bottom of the swing. The subject area pertains to mechanics, specifically the concepts of energy conservation and motion dynamics.
  • Participants discuss the conservation of energy, questioning the types of energy involved at different points in the pendulum's motion. There is an exploration of whether the motion is accelerated and if the acceleration is constant, which may influence the choice of applicable formulas.
Some participants have suggested considering the conservation of energy as a potential approach, while others have pointed out the need to clarify the nature of the motion before applying formulas. There is an ongoing exploration of the relationship between potential and kinetic energy, with hints towards equating them to find the speed.
Participants have noted the initial conditions of the mass and the length of the rope, but there may be assumptions regarding the absence of air resistance or other forces that could affect the pendulum's motion.
Yae Miteo
A mass m = 5.5 kg hangs on the end of a massless rope L = 1.81 m long. The pendulum is held horizontal and released from rest. How fast is the mass moving at the bottom of its path?
[tex]a_c = \frac {v^2}{r}[/tex]
[tex]F = ma[/tex]
[tex]v = v_o + at[/tex]
I attempted to solve the problem by coming up with a formula, and then plugging in the numbers. To begin,
[tex]F = ma = m \frac {v^2}{r}[/tex]
[tex]v = v_o + at = 0 + t \frac {v^2} {r}[/tex]
so more neatly
[tex]F = m \frac {v^2}{r}[/tex]
[tex]v = t \frac {v^2} {r}[/tex]
but from here I'm stuck. I'm not sure how to find time, or even if it needs to be found at all. Any suggestions?
Think of the conservation of energy:
what kind of energy does the mass have initially?
In which another kind of energy is then transformed into, once you drop the mass and let it swing?
Before jumping to formulas, think what kind of motion is this. Is this accelerated motion? Is the acceleration constant?
Then you can decide what formula will apply to it.
The initial energy will all be potential (PE = mgh) and the final energy will be entirely kintic (KE = 1/2 mv^2)
Yes .By equating PE and KE can you find v?
You're right, Yae Miteo. And you have all the data to compute those numbers and find v. ;)
  • · Replies 26 ·
17K
  • · Replies 21 ·
