Penetration of an energy step when KE > U
OEP
An electron with KE = 8eV is incident on the potential step of height 7eV. What's the probability the electron will be reflected from the step function?
The wave equations and their derivatives:
\psi_0(x) = A sin(k_0 x) + B cos( k_0 x)
\psi_1(x) = C sin(k_1 x) + D cos( k_1 x)
\psi_0'(x) = A k_0 cos(k_0 x) - B k_0 sin(k_0 x)
\psi_1'(x) = C k_1 cos(k_1 x) - D k_1 sin(k_1 x)
Plus values for k:
k_0 = \sqrt{\frac{2m}{\hbar^2} (7eV)}
k_1 = \sqrt{\frac{2m}{\hbar^2} (1eV)}
First I solved the two wave functions evaluated at 0, which yields:
B = D
Next, I solved the two derivatives evaluated at 0, which yields:
A k_0 = C k_1 \rightarrow C = \sqrt{7} A
From here I'm lost.
I also did the same thing with complex exponentials... but I think I ended up with a nonsensical k_0 = sqrt(7) k_0.
\psi_0(x) = A' e^{i k_0 x} + B' e^{-i k_0 x}
\psi_1(x) = C' e^{i k_1 x} + D' e^{-i k_1 x}
\psi_0'(x) = i k_0 A' e^{i k_0 x} + i k_0 B' e^{-i k_0 x}
\psi_1'(x) = i k_1 C' e^{i k_1 x} + i k_1 D' e^{-i k_1 x}
D' = 0, we are firing particles from right to left, not left to right.
\psi_0'(0) = \psi_1'(0) \rightarrow i k_0 A' + i k_0 B' = i k_1 C'
\psi_0(0) = \psi_1(0) \rightarrow A' + B' = C'
i k_0 A' + i k_0 B' = i k_1 C' \rightarrow i k_0 A' + i k_0 B' = i k_1 (A' + B')
i k_0 = i k_1
Which is nonsensical. Any ideas? This seems like one of those good ol' problems that you first learn to solve, but... our professor is just a bit zany and I can't follow him. :P
I prefer the exponential notation as it is clear what is moving right & left
you have missed a negative in you differentiation
should get
A + B = C
and
k0(A-B) = k1C
then solve these for reflection amplitude is r = A/B, probability r^2
Thanks a lot! I guess it's being so over my head that I tend to overlook the smaller things... I have R being at 2.64 which I don't think is right for its square being a probability. We aren't looking for B / A are we?
i know what you mean -
& yep, you're right B/A should do it
Thanks again. I'm off to trudge through the rain and turn this sucker in.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
