Period of Pendulum A vs B: Find Faster Rate
  • Thread starter Thread starter CivilSigma
    Pendulum Period
Pendulum A, with a length of 20 cm and a 5g mass, has a period of 0.20 seconds, while Pendulum B, with a length of 30 cm and a 10g mass, has a period of 0.25 seconds. The mass of the pendulum does not affect the period, which is determined by the length of the pendulum. The correct formula for the period of a simple pendulum is needed for accurate calculations. It is suggested to look up the formula rather than derive it from complex equations. Understanding the relationship between length and period is crucial for solving pendulum problems effectively.
CivilSigma
Pendulum A is 20 cm long and has a 5g mass on it. Pendulum B is 30 cm long and has 10g mass on it. Which one has a faster period?
d=v1t+0.5at^2
First of all, does the mass of the pendulum matter at all? and if not then it I would need to find the time in both cases and divide by 1 right?
Time Pendulum A= 0.20 s which means that the period is 0.20 s.
Time Pendulum B= 0.25 s which means that the period is o.25 s.
Am I right? Thank you in advance.
Nope.
Whence these numbers?
Am I right? Thank you in advance.[/QUOTE]
No.
What's the formula for the period of a simple pendulum?
I do not know because we have not learned it. >.<
Then you'll have to derive it from the differential equation relating restoring torque to angular acceleration for small deviational angles.
Really it would be simpler for you to just look it up though.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
