Why is the phase constant negative in part B of this graph?
The negative phase constant in part B of the graph indicates a rightward shift of the cosine wave. This is because a negative phase angle translates the curve in the positive x direction, while a positive angle would shift it to the left. The solutions for the phase angle include both positive and negative values, but the correct choice for a right shift is the negative solution. Understanding that the phase angle represents a translation along the x-axis is crucial for interpreting the graph correctly. Therefore, the negative sign is essential for aligning the cosine curve with the given graph.
neoking77
all the solution is there, but i just don't understand the answer to part B.
for part B, why is the sign negative?
The graph is a cosine wave shifted to the right by an angle less than 90...
So of your two solutions (+pi/3 -pi/3) for arccos, you need the one with the minus, for a right shift, as opposed to a left shift...
Remember that there are an infinite number of solutions to trigonometric equations, so in your case;
\cos\phi = \frac{1}{2} \Rightarrow \phi = -\frac{\pi}{3}, \frac{\pi}{3}, \frac{5\pi}{3}...
\phi = \frac{\pi}{3} \pm 2\pi\cdot k \hspace{1cm}; k\in\mathbb{Z}
But the thing to remember here is that the phase angle is simply a translation along the x axis. A positive phase angle translates the curve in the negative x direction (to the left) and a negative phase angle translates the curve in the positive x direction (to the right).
Now, in which direction do we need to translate the cosine curve so that is matches yours?
Edit: Several mintues to slow ... :frown:
thanks a lot learningphysics and house md
I have iqbal too =O ubcccc
