Phase Transitions: Why is the pressure constant?
During phase transitions, the assumption that pressure (dP) remains constant is based on the fact that the system equilibrates with the surrounding ambient pressure. This allows the relationship dH = TdS to hold true. When phase changes occur in a non-constant pressure environment, the integral of volume times pressure change must be considered. Additionally, temperature is assumed constant during phase transitions because energy input primarily facilitates structural changes rather than increasing molecular motion. Understanding these principles is crucial for accurately analyzing thermodynamic processes.
madshiver
I have a question regarding phase transitions:
It all textbook I've seen the assumption that dP=0 during a phase transition (so that for example dH=TdS is true during a phase transition). Could anyone explain why this should be true?
I guess I could relate this question to a question I had during intro (Halliday) Physics: Why can we assume that temperature is constant during a phase transition? (Back then I imagined that after a certain point putting in energy to get the molecules to move faster does not really lead to a substantial increase in entropy, so that the rigid structure e.g. of the solid or the liquid has to be broken down, so that subsequent temperature increase would actually lead to a decent entropy increase, at the cost of reduced internal energy.)
And then the final related question: Why can't the pressure and temperature both change by "wandering" along the phase-transition line?
For a phase change in the open atmosphere, the pressure of the system is always equal to the ambient pressure of the surroundings ie the atmosphere. If the phase change takes place in an environment in which pressure is not constant, you would have to take the ∫VdP term into account. In such a case ΔH = ∫dH = ∫TdS + ∫VdP
AM
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
