Physics 2 question velocity of electrons and voltages
To determine the potential difference required to accelerate an electron from 1.00×10^6 m/s to 9.90×10^6 m/s, the kinetic energy equations are applied. The initial and final kinetic energies are calculated, resulting in values of 4.55×10^-19 J and 4.45×10^-17 J, respectively. The potential difference is derived from the change in kinetic energy, leading to a calculated voltage of approximately 275.282 V, noting that the electron moves against the electric field. Clarification is sought on the relationship between voltage and kinetic energy, specifically how V=U/q0 can be expressed as V=K/q0. The discussion emphasizes that the electron gains energy through a positive potential difference, aligning with the physics of electron acceleration.
rasanders22
Prob statement:
An electron is to be accelerated from a velocity of 1.00×10^6 m/s to a velocity of 9.90×10^6 m/s . Through what potential difference must the electron pass to accomplish this?
equations:
v=U/q0
1/2mv^2
U=K (this is where I have a question)
Well I already have the answer. But here's how I got it.
Ki=.5(9.11*10^-31)(1*10^6)^2=4.55*10^-19J
Kf=.5(9.11*10^-31)(9.9*10^6)^2=4.45*10^-17J
Vi=Ki/(-1.6*10^-19)=-2.843V
Vf=Kf/(-1.6*10^-19)=-278.125V
V=Vi-Vf=275.282V But the voltage is negative because the electron is flowing against the + to - field (atleast how i explained it to myself)
Well my first question is how does V=U/q0 turn into V=K/q0. I found one example where my instructor used this to determine the voltage but I can't find any reference to it in my book.
Thanks
Not sure what your Vi and Vf business is all about. Basically you want to add a certain amount of KE to what the electron already has (your Ki). So you have a desired ∆KE which is Kf - Ki.
The electron will gain energy falling through a potential difference: ∆KE = -q∆V. Since the required energy gain is positive in this case, and since q is negative, then ∆V should be a positive potential change (the electron should be accelerated by a positive potential).
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
