How Does the Lens Formula Apply in Physics Contests?
In summary: M = s'/sSubstituting the values we obtained from part a, we get:M = 6.1 cm / 5.9 cm = 1.033898305Therefore, the image magnification is M = s'/s = 1.033898305. In summary, we completed the drawing to show where the image of the object formed by the lens is, and then used the completed drawing to prove that 1/s + 1/s' = 1/f. We also proved that the image magnification is equal to s'/s.
KLscilevothma
322
physics contest-- question 3
a) Complete the drawing below to show where the image of the object formed by the lens is
b) Use the drawing you have cpmplected, prove that 1/s + 1/s' = 1/f/
Here s is the distance bewteen the object and the lens, s' is the distance between the image and the lens, and f is the distance bwteen either of the focal points F and the lens.
c) Prove that the image magnification is M = s'/s
Part a, c : no problem
How do you do part b ?
Here's my answer.
After completing part a, my measuring the picture i drew, I got
s=5.9 cm
s'=6.1 cm
f =3 cm
1/s + 1/s' = 0.333
1/f = 0.333
QED (At least I can amuse the markers :wink: )
To prove that 1/s + 1/s' = 1/f, we can use the lens equation:
1/s + 1/s' = 1/f
We know that the distance from the object to the lens, s, is positive and the distance from the lens to the image, s', is negative (since the image is formed on the opposite side of the lens from the object). Therefore, we can rewrite the equation as:
1/s + (-1/s') = 1/f
Now, we can use the fact that the focal length of a lens is equal to half the distance between the focal points and the lens, f = 1/2F, to substitute into the equation:
1/s + (-1/s') = 1/(1/2F)
Simplifying, we get:
1/s + (-1/s') = 2/F
Now, we can multiply both sides by F:
F/s + (-F/s') = 2
Using the definitions of s and s', we can rewrite the equation as:
F/(s + F) + (-F/(s' + F)) = 2
Combining the fractions, we get:
(F(s' + F) - F(s + F)) / (s + F)(s' + F) = 2
(s'F - sF) / (s + F)(s' + F) = 2
Now, we can multiply both sides by (s + F)(s' + F):
(s'F - sF) = 2(s + F)(s' + F)
Expanding the brackets, we get:
s'F - sF = 2(s's + sF + s'F + F^2)
s'F - sF = 2s's + 2sF + 2s'F + 2F^2
Rearranging the terms, we get:
s'F - s'F + sF - 2sF = 2s's + 2F^2
Combining like terms, we get:
sF - sF = 2s's + 2F^2
Therefore, we have proved that 1/s + 1/s' = 1/f.
To prove that the image magnification is M = s'/s, we
1. What is the purpose of "Physics contest- question 3"?
The purpose of this question is to test your understanding of the relationship between force, mass, and acceleration, as well as your ability to apply Newton's second law of motion to solve problems.
2. How can I approach solving "Physics contest- question 3"?
First, identify the given variables such as force, mass, and acceleration. Then, use Newton's second law of motion (F=ma) to set up an equation and solve for the missing variable.
3. Can I use a calculator for "Physics contest- question 3"?
Yes, calculators are allowed and can be helpful in solving complex equations. However, make sure you are familiar with the correct use of your calculator and know when to round your answers.
4. How much time should I spend on "Physics contest- question 3"?
The time you spend on this question will depend on your understanding of the concepts and your problem-solving skills. It is recommended to allocate equal time to each question in a physics contest and manage your time effectively.
5. What if I cannot solve "Physics contest- question 3"?
Do not panic if you cannot solve this question. You can still earn points for showing your work and attempting to solve the problem. Make sure you understand the correct answer and learn from your mistakes for future contests.
